Blipblop75 Posted May 21, 2014 Share Posted May 21, 2014 I just bought "Metal Pack" add-on from Line-store.I have run Licence manager and I have it in the list for my Pod XT that is also authorized.But were is it in my pod?I have my standard 15 A-D presets and User 16 A-D presets, but thats all.Were can I find the new presets? :wacko: :huh: Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted May 21, 2014 Share Posted May 21, 2014 there are no new presets... you can just use the model pack models now to make your own tones... or download tones that use those models from customtone.com Quote Link to comment Share on other sites More sharing options...
Blipblop75 Posted May 21, 2014 Author Share Posted May 21, 2014 aha.. so, one of the Sound examples in this Metal Shop add-on page http://line6.com/modelPacks/metal.html let's take "Bomber Uber" for an illustrative example, I can download it from customtone.com (a .lt6 file that works with podfarm,) but how can I get that file into my pod? I wish to use my pod and new sounds without computer, is it possible? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted May 21, 2014 Share Posted May 21, 2014 you have to use gearbox or line6 edit to get it to the pod. Quote Link to comment Share on other sites More sharing options...
Blipblop75 Posted May 21, 2014 Author Share Posted May 21, 2014 Oh.. software jungle.Is there any instructions for this, I didnt find any in the manual for Gearbox? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted May 21, 2014 Share Posted May 21, 2014 there are some manuals here for gearbox: http://line6.com/support/manuals/podxt Quote Link to comment Share on other sites More sharing options...
Blipblop75 Posted May 21, 2014 Author Share Posted May 21, 2014 I can't find the new amps either in the pod?Whats wrong? Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 21, 2014 Share Posted May 21, 2014 You don't need to download any files to get the amps on the list you linked to. They are just available on your PODxt now. getting downloaded files to your PODxt is if you want presets from costumtone or that some has shared. Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 21, 2014 Share Posted May 21, 2014 I can't find the new amps either in the pod? Whats wrong? When you power up the PODxt, do you see the Metal Shop logo on the splash screen? Quote Link to comment Share on other sites More sharing options...
Blipblop75 Posted May 21, 2014 Author Share Posted May 21, 2014 No :'( Quote Link to comment Share on other sites More sharing options...
Blipblop75 Posted May 21, 2014 Author Share Posted May 21, 2014 It jumps directly to a preset when power up, no splash screens at all Quote Link to comment Share on other sites More sharing options...
Blipblop75 Posted May 21, 2014 Author Share Posted May 21, 2014 Metal Shop is in the list in the Licence Manager under Devices PODXT (and also PC) and is autorized.But no change in POD yet. I have USB connected Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 21, 2014 Share Posted May 21, 2014 Can Monkey see it and has green ticks for firmware/drivers? If not, you might need to reflash you PODxt. If there are presets you tweaked and do not want to lose, back them up with Gearbox first. Quote Link to comment Share on other sites More sharing options...
Blipblop75 Posted May 21, 2014 Author Share Posted May 21, 2014 I have some green and flash is white and is missing in the installed collum?It looks like this:https://www.dropbox.com/sh/ts84dtdv43j8juz/AADuBuIUH0Kc138M36l1i-lla#lh:null-20140521_232622.jpg Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 22, 2014 Share Posted May 22, 2014 That is the issue. It needs to be flashed. If the Monkey cannot flash it, try a different USB cable and USB ports. 1 Quote Link to comment Share on other sites More sharing options...
Blipblop75 Posted May 22, 2014 Author Share Posted May 22, 2014 Hurray!!Now it works! This thread was a healp: http://line6.com/supportarchivenew/thread/6223 From what I understand there is some erly/older POD xt versions that can not flash thru an USB cable, but only thru MIDI cables via soundcard or USB/MIDI adaptor.So I Flashed the pod thru my soundcard via MIDI and it worked!I got the splashscreen now :) 1 Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted May 22, 2014 Share Posted May 22, 2014 after you flash up, the usb should work even for future flashes... (although there wont be any!...) just saying for the record that the midi flash is only necessary to flash above a certain level to gain full access to the usb functionality. Hurray!!Now it works! This thread was a healp: http://line6.com/supportarchivenew/thread/6223 From what I understand there is some erly/older POD xt versions that can not flash thru an USB cable, but only thru MIDI cables via soundcard or USB/MIDI adaptor.So I Flashed the pod thru my soundcard via MIDI and it worked!I got the splashscreen now :) Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 22, 2014 Share Posted May 22, 2014 Cool!! Glad you got it going. Flashing via MIDI crossed my mind, but since you had green for go on the USB firmware and drivers I didn't think that was the case. Quote Link to comment Share on other sites More sharing options...
Blipblop75 Posted May 22, 2014 Author Share Posted May 22, 2014 Tanks for all the help Real Zap and Triryche! :) Quote Link to comment Share on other sites More sharing options...
