HarryFromAten Posted May 22, 2014 Share Posted May 22, 2014 I ordered my Pod hd pro from America (i'm from England) and it came with the power cable but it's an American one so it won't fit my plug sockets. I will most likely just get an American to English plug adapter but i was wondering if i can use a kettle lead (power cable) that is 10A 250V for the pod? On the pod above the power input it says 100-240V 50 - 60Hz 100w max so i didn't know if it would overpower it? or break it in some way? I have loads of 250v power cables already so it will be great if i can just use one but if it's going to damage my pod i'll just get an adapter or buy a power cable thats 240v. Any help would be great, thanks Harry Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 23, 2014 Share Posted May 23, 2014 The Pod HD power supply is universal; you should just need an adapter - not a converter. Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted May 23, 2014 Share Posted May 23, 2014 You don't even need an adapter as the you can use a standard UK IEC (kettel) mains lead. UK voltage is officially 230V now although I think we still hit 240V in actuality due the the allowed +/- tolerance. Quote Link to comment Share on other sites More sharing options...
HarryFromAten Posted May 23, 2014 Author Share Posted May 23, 2014 You don't even need an adapter as the you can use a standard UK IEC (kettel) mains lead. UK voltage is officially 230V now although I think we still hit 240V in actuality due the the allowed +/- tolerance. So i can use a 250V kettle lead for the POD? i was just worried as the POD says it takes 240V Quote Link to comment Share on other sites More sharing options...
