Signal routing (POD USB + multiple cards)
pod hd500 usb asio kxmixer signal routing cubase
Best Answer TheRealZap , 27 May 2014 - 04:44 AM
Sound quality, latency, additional digital to analog conversions, possible noise introduced by cables or lower quality sound cards in the signal path.
A few quick examples.
It's really not worth it to avoid an occasional volume adjustment IMO Go to the full post
9 replies to this topic
#1 Harmont
Harmont
  • 5 posts
Posted 27 May 2014 - 03:02 AM
I use Cubase to record guitar via POD HD500. I want to connect POD by USB and have ability to listen to a backing track from Winamp.
Correct me if I'm wrong:
1. There's no way to send multiple audio sources to an audio card if you use ASIO. Which means if you connect POD via USB, you cannot hear guitar sound sent through Cubase (first source) and backing track from Winamp (second source).
2. You can, however, connect POD via Line In to an audio card and listen to both. Input signal from Line In is mixed internally by an audio card with signal from Windows kxmixer. ASIO in that case is not needed.
Now a question:
3. If I have two audio cards in my PC, can I process signal from POD USB by first card, daisy chain both cards (Line Out to Line In) and then mix resulting signal on the second card and send output signal to speakers? This essentially means that Windows will have to send POD signal to first card and kxmixer signal to the second. I don't know if it's even possible. I'll probably need some signal routing software to accomplish that. Thoughts?
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 27 May 2014 - 03:12 AM
the pod will become your soundcard and can play all the songs from your computer including cubase etc...
using multiple cards isn't practical or needed.
#3 Harmont
Harmont
  • 5 posts
Posted 27 May 2014 - 03:39 AM
Well yeah, I forgot to mention that. However, if I connect my speakers to the POD I'll have to use master and volume controls on the POD to change the volume level. Is that true? Because it's kinda awkward to bend every time I need to slightly change the sound volume.
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 27 May 2014 - 03:42 AM
If you save all your tones at a similar "channel volume" then you should primarily only have to deal with the master volume.
but yes, that's the way it works.
#5 Harmont
Harmont
  • 5 posts
Posted 27 May 2014 - 03:50 AM
Thanks for confirming that. Because this is really not handy. I agree that this is a matter of preference, but I'd rather avoid that.
Now, I already have two audio cards in my PC and it's just a question of whether I can use them in a way I described above. Is it even possible at all? Or I have to go with option 2 and just forget about the USB?
#6 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 27 May 2014 - 04:38 AM
There really isn't a good way to use multiple sound cards. You can do it if you're willing to make some compromises. Most including myself are not.
#7 Harmont
Harmont
  • 5 posts
Posted 27 May 2014 - 04:40 AM
Can you explain what these compromises are. Or give me links where I can read. Even key words would do. :) I simply do not know where to start and how to put this all together.
#8 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 27 May 2014 - 04:44 AM   Best Answer
#9 Harmont
Harmont
  • 5 posts
Posted 27 May 2014 - 04:50 AM
Ok, that makes sense. I still don't want to deal with volume adjustments on POD. And solution for me would be POD to Line In recording in that case.
Thanks for all your comments.
#10 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
  • Registered Products:6
Posted 27 May 2014 - 06:49 AM
I will just add that investing in a mixer will solve a lot of the inconveniences and swapping cables back and forth.
Doesn't have to be anything fancy.
Also tagged with one or more of these keywords: pod, hd500, usb, asio, kxmixer, signal routing, cubase
