kenzokas Posted May 28, 2014 Share Posted May 28, 2014 Hi! I am new to Wireless Systems since I've never used them, but on stage it is really uncomfortable to play with cable. SO, I'd like to purchase a Line6 wireless system, since I've heard that digital wireless system are kind of better than analog systems. So I've searched a little bit and found an interesting wireless system bundle from Thomann cyber store. It contains a Line6 Rx: V35 reciever and Line6 TX 35 bodypack. As the V35 is designed for microphones, does it still work with the TX35 bodypack or will I only face problems with this bundle? Or will it work the same way as the Line6 Relay G30 does? Second question would be with the Balanced and Unbalanced output, what is the difference between them? When I'm going to connect this with a guitar amp, then I'd probably use the Unbalanced output, but are going to be any problems with the sound when I do this? Quote Link to comment Share on other sites More sharing options...
dboomer Posted May 28, 2014 Share Posted May 28, 2014 The V35 and G30 series are basically the same radio but with different packaging. Sonically it will be the same but you won't have a foot pedal type receiver. There is no difference between the signal quality or level between the balanced and unbalanced outputs. You just use the appropriate one to match the system you are plugging into. Quote Link to comment Share on other sites More sharing options...
