Expression pedal - custom range?
expression pedal pitch glide
2 replies to this topic
#1 rotten77
rotten77
  • 10 posts
  • LocationCzech Republic
Posted 02 June 2014 - 09:22 AM
Hi, I have Bespeco VM12L expression pedal, which works great. But I have upgrade on it - MIDI switch for switch on/off wah (look at this topic). And there is foam on toe for "acidentaly not switch on/off" - look at photos. So, because there is foam, I have no "hard" position of toe. If I use wah-wah there is no problem, but when use Pitch Glide (whammy) I can set toe position to (for example) +12.0 but because that foam, it can sometimes change (ex. +11.8 - +12.1, because I sometimes make greater pressure than before). So there is my question: It is there some way to set cusotm range for expression pedal? I mean, can I set for example this:
Pedal at 0 - 4 % => do nothing
Pedal at 5 % => "start position" of expression pedal (=> 0%)
Pedal at 6 - 94% => do stuff
Pedal at 95 % => "end position" of expression pedal (=> 100%)
Pedal at 96+ % => do nothing
For better understanding look at image:
Line6 M13, Fulltone Fulldrive 2, MXR Doubleshot Distortion, Engl E320 combo and Tokai Silverstar from 1985
#2 NickBell
NickBell
    Line 6 U.S. Product Specialist
  • Product Specialist
  • PipPip
  • 183 posts
  • LocationCalabasas, CA
  • Registered Products:4
Posted 17 June 2014 - 02:11 PM
Hey Rotten77,
 The M Series auto saves with any paremeter when using an expression. Set your toe position to its max, then manually set the paremeter via the knob to your disired max output volume. Do this same process for where you would want your heel volume to be. When you test the expression pedal you'll see the new set range.
This can be done with any effect within the M Series.
  • -1
Follow me on Twitter @Line6Nbell
#3 rotten77
rotten77
  • 10 posts
Posted 17 June 2014 - 09:04 PM
Hey Rotten77,
Yes, this is standard situation, but because there is foam (as I write in first post), I have no "hard" position of toe so I need to setup expression something like "toe at 95 % is max, more than 95 % do nothing"
Also tagged with one or more of these keywords: expression pedal, pitch glide
