How to monitor POD HD500X output signal level?
pod hd500x output signal level
Best Answer Digital_Igloo , 05 June 2014 - 08:08 AM
I connect my XLR outputs on the PODHD500X to a set of KRK Rockit 5 monitors, and the signal is extremely weak and I have to crank the level on the speakers, the level on my monitor controller, and the master output on the POD to get adequate volume out of the speakers.
The XLR outputs on POD HD500X are mic level—that is, they're designed to be sent long distances (without the need for additional DI boxes) to the front-of-house mixer and then boosted with mic preamps.
The 1/4" outputs are line level, which is much higher. If you're running directly into studio monitors, definitely use the 1/4" outputs.
Go to the full post
11 replies to this topic
#1 TylerSocholotuik
TylerSocholotuik
  • 14 posts
  • Registered Products:2
Posted 02 June 2014 - 02:30 PM
Hello,
I connect my XLR outputs on the PODHD500X to a set of KRK Rockit 5 monitors, and the signal is extremely weak and I have to crank the level on the speakers, the level on my monitor controller, and the master output on the POD to get adequate volume out of the speakers. I have even started boosting the levels on the mixer to about +3 dB, but I don't want to go higher than that cause I don't know if I am clipping.
I think it is pathetic that there is no indicator on the pod to tell you if you are clipping or not. Is there any way I can monitor this? There is an output meter on POD Farm, but not in the HD Edit software.
Thanks in advance
#2 pfsmith0
pfsmith0
    Gear Head
  • PipPipPip
  • 616 posts
  • Registered Products:1
Posted 02 June 2014 - 07:55 PM
I'm with you - a grave under sight. I monitor overload by taking the SPDIF output into my sound card. That way you can at least tell if the output is clipping. I don't know any way to tell if the internal stages are clipping other than to start at the input and route it to the SPDIF out to check, Then add the 1st FX and check again. Then add the 2nd, etc. until finally you get the whole signal chain checked out. What a pain and to tell you the truth, I've never done it. I just look at the final output. In my setup that's usually the loudest signal anyway.
#3 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1205 posts
Posted 03 June 2014 - 12:25 AM
It certainly would be handy to have a output meter.
It could be part of the High Definition with a Pod HD is in the processing being done .
It could be like it is in 32bit floatintg point where there actually isn't internal clipping no matter the digital overs.
Going into an amp this hot level might be beneficial.
(Not a theory but a guess)
If you connect an output like the s/pdif to DAW you can see if it is clipping or not.
Usually you'l be able to hear digital clipping.
#4 TylerSocholotuik
TylerSocholotuik
  • 14 posts
Posted 04 June 2014 - 07:04 PM
I am currently using a laptop, so I don't have a S/PDIF input. When I record, my guitar track doesn't clip at unity gain, so I am probably ok.
#5 xpanmanx
xpanmanx
  • 58 posts
  • LocationUSA
  • Registered Products:7
Posted 05 June 2014 - 07:05 AM
http://bit.ly/1kBQrlZ --- Does this help? $60 online.
#6 Digital_Igloo
Digital_Igloo
    Line 6 Staff
  • Product Management
  • PipPipPipPip
  • 1970 posts
  • LocationCalabasas, CA
Posted 05 June 2014 - 08:08 AM   Best Answer
  • 1
Senior Product Manager, Line 6
#7 TylerSocholotuik
TylerSocholotuik
  • 14 posts
Posted 06 June 2014 - 12:18 PM
Ahh, I didn't know the XLR outs were mic level.
That is kind of annoying since the 1/4" outputs are unbalanced. I don't really want to use a DI box.
#8 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1205 posts
Posted 06 June 2014 - 06:10 PM
You could add a VU or LED meter to the phones output with a capacitor across it as it is powered by the headphone amp built in the HD
But the line outs could drive a VU without the cap.
Just get a VU meter and a TS plug and you got one side mono.
Of course you'd have to calibrate the meter by comparing to the metering in a DAW.
#9 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 07 June 2014 - 05:49 AM
Unfortunately with a digital processor, monitoring the output doesn't tell you if it's clipping.  It could clip elsewhere in the chain.  These boxes should have a digital clipping indicator to help us prevent  clipping due to overdriving things.
#10 billlorentzen
billlorentzen
    Iknowathingortwo
  • PipPip
  • 434 posts
  • LocationFlorida, USA
Posted 07 June 2014 - 10:02 AM
Studio monitors are not designed for a mic level input. That's no fault of the pod. As to clipping, do any pedals, amps or even rack fx (other than some compressors) have output meters?
As an earlier poster said use the 1/4 outs. I wouldn't worry about it not being balanced unless you're recording, and then you could run into a mic pre anyway.
#11 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 07 June 2014 - 10:21 AM
Clip indicator is important - more so than an output level meter.
#12 TylerSocholotuik
TylerSocholotuik
  • 14 posts
Posted 09 June 2014 - 08:17 AM
Thanks for the responses, everyone.
I'll just use the 1/4" outputs, then I can turn everything down and not worry about clipping. I'm in a small room so it shouldn't be a problem.
Also tagged with one or more of these keywords: pod, hd500x, output signal level
