Pocket Pod to Guitar Link - Sound only in left ear
7 replies to this topic
#1 DoubleDown
DoubleDown
  • 5 posts
Posted 04 June 2014 - 04:15 PM
I have the pocket pod running into a Behringer Guitar Link interface into my laptop.  I have sound, I can record, all is good.  But whether I run it out of the pod from "Direct Out" or "Amp out" I'm only getting sound in my left ear and it's only recording the one side.  What setting do I need to change somewhere that will give it the full sound?  Any help is greatly appreciated.
Thanks,
Mike
#2 DoubleDown
DoubleDown
  • 5 posts
Posted 04 June 2014 - 05:02 PM
Using the Pocket Pod to record but I'm only getting sound from one side of the headphones.and on my recording software.  I'm running a cable from the "direct out" to an interface to my laptop.
Any help is appreciated.
Thanks.
#3 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
  • Registered Products:6
Posted 05 June 2014 - 10:15 AM
Make sure you are using a stereo (TSR) cable.
#4 DoubleDown
DoubleDown
  • 5 posts
Posted 05 June 2014 - 11:35 AM
Thanks.  I'm sure this looked like a stupid question and I suppose I overlooked the obvious, but I record stuff all the time with different devices and never had this issue with the cables I have.  Guess the pocket pod threw me a curve ball.  Ha...   Thanks again.
#5 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
Posted 05 June 2014 - 02:41 PM
What interface are you using?
#6 DoubleDown
DoubleDown
  • 5 posts
Posted 05 June 2014 - 02:52 PM
Behringer Guitar Link UCG102
#7 DoubleDown
DoubleDown
  • 5 posts
Posted 05 June 2014 - 03:51 PM
Problem solved.  It wasn't the cable.  There was a setting in Cubase for 1 or 2 channels in Input and Output.  It was defaulted to 2 which is how it has always been set for recording with another device.  I changed it 1 and now it's fine.
Now if I can just figure out this latency thing.  Never had to deal with that before.  Trying to minimize the delay between hitting the strings and hearing it in my headphones.
#8 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
Posted 05 June 2014 - 04:05 PM
If you are plugging you guitar into the POD 2.0, just run the POD 2.0 directly to your laptops line in.
Using the link is adding an extra step is may be causing the latency.
The link is more for taking your guitar signal and pumping down USB.
