How to add two of the same effect on the Amplifi app?
austinctu24
I didn't think two delays was a option unless one of them is  dual delay which is more of a single effect than truly two delays. If you are running through an amp with effects, you can use the delay there otherwise you will need an additional stomp box. Running through mutliple delays is how Brian May gets his harmonizing sounds.
