Mic Barely Audible
4 replies to this topic
#1 EricDellOrco
EricDellOrco
  • 2 posts
  • Registered Products:1
Posted 04 June 2013 - 03:36 PM
Hey so I'm new to home recording and have a Shure SM58 hooked to the ux2. I'm am using garageband for track recording and am having an issue where I can barely hear my mic at full volume without cranking up gain settings on garageband. I have tried messing with the gain knobs on the ux2 but that results in either noise or feedback. I have also tried using the preamps on pod farm 2 without success. Any suggestions? I'm using a MacBook Pro 2012 2.6 GHz
#2 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2559 posts
  • LocationNew England
  • Registered Products:3
Posted 05 June 2013 - 05:11 AM
You are using an XLR-XLR cable, correct?   I am not familiar with garageband, but in most DAWs you have to select the correct inputs from your interface - make sure you have the mic inputs selected and routed correctly (i.e. mic 1 > track 1, etc.)
You mention feedback - you should have any monitor speakers you are using turned off when using a microphone (use headphones to listen to prerecorded tracks and to monitor what you are recording).
#3 EricDellOrco
EricDellOrco
  • 2 posts
Posted 06 June 2013 - 11:17 AM
Yes I am using an XLR to XLR. The inputs are correctly selected I can hear the mic. The Issue is that I have guitar tracks in my project that were recorded using the ux2 and the mic track is inaudible when I play them together unless I boost the gain. In doing so reduces the clarity of the vocals I recorded. Thanks for the monitoring tip definitely solved that issue!
#4 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7336 posts
  • Registered Products:6
Posted 06 June 2013 - 02:29 PM
Did you record the dry track for the mic? If so you will need to add the POD Farm 2.5 plug-in the the track.
This of course assumes you have the PF 2.5 plug-in. If you recently purchased a black faced POD Studio, this would be the case.
#5 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2559 posts
Posted 07 June 2013 - 07:35 AM
One mistake many people make when first staring out doing computer recording is recording too hot.   Your peak meters should be reading -18dB to -12dB when tracking.
Sounds like you just need to reduce the volume of your guitar playback tracks.
