How I got FBV MKii Shortboard/Monkey update to work!
3 replies to this topic
#1 rhayes71
rhayes71
  • 2 posts
  • Registered Products:2
Posted 09 June 2014 - 06:35 PM
After an extremely frustrating 6 hours I finally got Monky to work and got my FBV MKii and Spider IV 120 updates to work through trial and error. Now that I finally got it done, I am happy again!
I will share what worked for me and it was not any issues with a firewall, USB cable, new computer or latest version of Windows.
1. Download the monkey software.
2. Restart your computer after downloading monkey.
3. Make sure your FBV MKii is plugged into your amp.
4. UNPLUG any and all extra cables from your amp! Leaving your guitar cable or a 3.5mm cable for an MP3 player plugged into your amp gives Monkey the SH**TZ, causes the error boxes, and will not detect your devices!
5. So now you only have the power cable into your amp and the FBV MKii connected to the amp (no other cables!) turn the amp on.
6. Next plug the USB cable into the FBV MKii then into your laptop and let windows detect it.
7. Open Monkey, let it connect to the servers then it will search for your devices.
8. Now you should get a pop up box listing the FBV MKii and your amp.
9. Click on the FBV MKii to select it.
11. Sign in using u=your username and password to get permission to update.
10. Complete your FBV MKii updates.
This was the only way I could get mine to work and not get the errors or have Monkey not detect my devices. After updating your FBV MKii and if you have an amp that needs updating, close monkey, shut the amp off, unplug your USB from your computer, and go back to step 2. Follow the same sequence only this time you will select your amp to update from the pop up box.
Hope this helps some of you folks experiencing the same issues I had.
  • 2
#2 schumley
schumley
  • 2 posts
Posted 21 July 2014 - 01:04 PM
I'm going to try this tonight and I'll post my results.  I've tried two computers, different USB cables and every USB jack I have and it wont get detected.  I'm at a loss.
Thanks!
#3 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2557 posts
  • LocationNew England
  • Registered Products:3
Posted 22 July 2014 - 04:10 AM
Actually, you need to do this with the FBV NOT connected to the amp first, as you need to update the FBV firmware first.
Depending on your O/S, you also need to turn off all firewall and anti-virus software, too.
#4 schumley
schumley
  • 2 posts
Posted 24 July 2014 - 06:27 PM
fflbrgst - thanks for that tip!  I go the Monkey to update my FBV.  But can someone please tell me how to get Spider IV Edit to detect my FBV?  Spider IV Edit still wont detect it even with the Monkey update.
Thanks!
