Gfer1484 Posted June 14, 2014 Share Posted June 14, 2014 How do I setup the HD500X too use two amps at the same time, I see that you can add duel amps models and switch between them, but I would like to run two different amp models at the same time using the 1/4 inch left and right outputs to two different amps, so one amp to left output and one amp to right output, running at the same time, can that be done Quote Link to comment Share on other sites More sharing options...
duncann Posted June 14, 2014 Share Posted June 14, 2014 Sure this can be done. Just place one amp in path A and one in path B. Then adjust the mixer pan control for each path to 100%L and 100%R. Keep in mind that each of the two paths are stereo signals. Also make sure there are no mono or summing effects after the mixer block. Quote Link to comment Share on other sites More sharing options...
Gfer1484 Posted June 14, 2014 Author Share Posted June 14, 2014 Thanks I will give it a try Quote Link to comment Share on other sites More sharing options...
Gfer1484 Posted June 20, 2014 Author Share Posted June 20, 2014 Thanks for the info duncann. I setup duel amp's 1st/A Treadplate with 412 Tread V-30 2nd/B Treadplate with 412 XXL V-30,noise gate, EQ, I cant believe the sound that I am getting just running threw a Marshall MG100 DFX and Line 6 Spider IV 30. I am very pleased with the HD500X, you cant be the tone emulation. Quote Link to comment Share on other sites More sharing options...
duncann Posted June 20, 2014 Share Posted June 20, 2014 Glad to hear you figured it out. Technology can certainly be a wonderful thing. I'm quite satisfied with 500x also. There is a downside though. The more you dig in, the greater the chance of subjecting yourself to hours, days, and weeks of frustration; this kind of depends on your personality. If you're the type that likes to try nearly every possibity (which the 500x supplies in large quantities) be prepared for that. 1 Quote Link to comment Share on other sites More sharing options...
ceccez Posted June 20, 2014 Share Posted June 20, 2014 Hi! I'm also very pleased with pod tones, especially high gain Treadplate, like you. I tried some PDXguitarfreak duel amp patches and with little editing they were awesome. Have you tried them? You can download patches: http://line6.com/customtone/profile/PDXguitarfreak/. For example "Daves's main tone" worked really well for me. There is also Youtube videos from him: http://youtu.be/hfVNbDtF-9Y. Quote Link to comment Share on other sites More sharing options...
Gfer1484 Posted June 24, 2014 Author Share Posted June 24, 2014 I agree on the down side, the POD HD500X is not a 4 knob floor pedal and you can easily get upset with it, once you learn and ask questions due your research on how to work the HD500X there is so much to learn and try, inputs outputs, plug in to the front of the amp or fx loop, the list goes on and on, what works for one may not work for others, you always have to tweak a patch. ceccez I have not tried guitar freak tones, I just finished down loading them and will give them a try. I have down loaded several patches from the web sight, and some are good some are not. METAL FOR LIFE Quote Link to comment Share on other sites More sharing options...
