Spider iv 120
7 replies to this topic
#1 canerakcil
canerakcil
  • 74 posts
  • Registered Products:1
Posted 15 June 2014 - 12:16 PM
I am planing to buy a spider iv 120 or maybe a 150 and wanted to ask some information from you guys..Is there anything negative you can say about this amps? Do you recommend them?
Thanks,
#2 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2572 posts
  • LocationNew England
  • Registered Products:3
Posted 16 June 2014 - 04:19 AM
What type of music do you play, what guitar(s) do you have?   How comfortable are you learning to program the user preset locaitons and learning how the amp works?
#3 canerakcil
canerakcil
  • 74 posts
Posted 16 June 2014 - 08:22 AM
I play metal and very familiar with line 6 products and their software style. I like the tones of Line 6 but i wonder if any specific problem existing on these amp series...
Amplifi series have bluetooth connection problem and amp chassis vibration issues on some models for example..
#4 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2572 posts
Posted 17 June 2014 - 04:29 AM
The only specific problems I am aware of with the Spider IV (and all of these only rarely occur except for the firmware updating).
1) Some active pickups overdrive the input circuit, buffering thorugh any kind of stompbox (with no true bypass) seems to solve it.
2) Firmware updating is sometimes tricky, getting Line 6 Monkey to identify your FB Mk2 pedal and amp.
3) Loose control knobs that can result in sound changes when playing loudly due to 'waking' of that control.
#5 b1363h
b1363h
  • 4 posts
  • LocationSouthwest USA
Posted 20 June 2014 - 02:36 PM
Tighten those knobs. Otherwise, a very good amp.
#6 canerakcil
canerakcil
  • 74 posts
Posted 22 June 2014 - 02:51 AM
How do you tighten the knobs? Do you pull the knob to make it come out or should i open the back plate?
Does the amp loaded with spider fx infusion 2.0 firmware from the factory?
#7 b1363h
b1363h
  • 4 posts
Posted 22 June 2014 - 07:45 AM
Gently, pull the knob off if your having trouble with loose knobs. Be careful, they are fragile, and check the nut behind the knob to see if it has worked loose. Now, those nuts are like the ones under your guitar volume and tone knobs. They break easily. After I tightened mine my Spider IV, 120 WORKS MUCH BETTER. The amp selection knob and the drive knobs are the culprits on my Amp. Now it works much better, but still will go to sleep on occasion. A guy mentioned someone used rubber spacers on there amp and solved the problem. Rock On.
#8 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2572 posts
Posted 23 June 2014 - 04:13 AM
Not every Spider amp has hte knob problem, mine doesn't.    Not sure if new amps come with the Infusion update already installed, you'd have to ask someone who just got one, or ask the factory.  It's fairly easy to install the firmware update, but you obviously need an FBV MkII pedal to do so.
