Can't hear all tones / Amp question
9 replies to this topic
#1 flukeson
flukeson
  • 3 posts
Posted 16 June 2014 - 01:41 AM
I'm a new user of the pod hd500, I have it plugged into a cheap guitar amp. Some of the presets play through the amp fine, but the majority don't, I cant hear anything, custom and default ones. I have the volume pedal down as well. I could be completely missing something here?
Is it because my amp can't handle it or what? What kind of amp do I need? Looking for something cheap that will work.
Thanks.
#2 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 16 June 2014 - 05:31 AM
No.  Your cheap amp should work with any tones.   Check the Input settings for the tones.  They are probably not right for whatever you have as an input.
#3 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
  • Registered Products:1
Posted 16 June 2014 - 05:36 AM
some amps have a very low initial volume. try increasing the drive or volume on amps you can't hear
I'M SO HAPPY!
#4 flukeson
flukeson
  • 3 posts
Posted 16 June 2014 - 06:31 AM
Thanks for the replies. That doesn't seem to work either, no sound coming whatsoever. Its very strange only 2 presets work on the entire pod (both customtones downloaded from this website)
Any other tips, something I should be seeing on the led screen?
#5 alienux
alienux
    Iknowathingortwo
  • PipPip
  • 273 posts
  • LocationDayton, Ohio
Posted 16 June 2014 - 08:21 AM
Is this POD new or used? If used, it could be that the original owner modified the input types to something that doesn't match or something like that.
If it's new, you should be able to hear the default presets, so as cruisinon2 said, you might want to try a factory reset. Otherwise, I'd call Line 6 support.
brian ®
http://brianmhall.wordpress.com - Guitars & Gaming
#6 DarrellM5
DarrellM5
    Gear Head
  • PipPipPip
  • 929 posts
  • LocationRound Mountain, NV
  • Registered Products:5
Posted 16 June 2014 - 10:10 AM
Some of the presets on mine came with the amps not toggled on.  I had to click the button next to the amp to get any sound.
#7 flukeson
flukeson
  • 3 posts
Posted 16 June 2014 - 12:05 PM
Its used. I reset to factory defaults removing everything and still nothing. I loaded on some customtones aswell and again its only the same one that works and the others don't. How would I go about modifying the input types? Strange that only one works but nothing else does (no matter where its placed in the bank)
#8 aussiejoe
aussiejoe
  • 13 posts
Posted 16 June 2014 - 01:34 PM
try moving the footpedal
it could be set as a volume pedal in the patches and is restricting volume of the patch
  • 1
#9 alienux
alienux
    Iknowathingortwo
  • PipPip
  • 273 posts
Posted 16 June 2014 - 06:20 PM
You can check input types on screen 3 of the system settings on the POD. The manuals here discuss how to do that:
http://line6.com/sup...anuals/podhd500
brian ®
#10 edstar1960
edstar1960
    Power User
  • PipPipPipPip
  • 1664 posts
  • LocationUK
  • Registered Products:7
Posted 17 June 2014 - 03:09 AM
Read the manual as referred to in the post from alienux:   http://line6.com/sup...anuals/podhd500
What have you got plugged in to the HD500 and what input socket have you got it plugged into?
How have you connected the HD500 to your amp?  What output socket are you using?
What have you got the MASTER control knob set to?
Do you hear anything if you plug headphones into the phones socket and listen on them?
