Help... US POD500 to AUS - Power??? Pedal Power 2 Plus?
pod500 pod 500 power australia usa 120v 240v voodoo pedalpower
3 replies to this topic
#1 spiro
spiro
  • 2 posts
  • Registered Products:1
Posted 16 June 2014 - 03:33 AM
Hey,
I just got a POD500 from the US.
Obviously, the power adapter is different.
I know the output is 9V - 3A.
Will my Voodoo Labs Pedal Power 2 Plus power this up? or do I need to a) get a AUS Power Supply for the unit or B) get a step down transformer for it?
Cheers.
#2 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 16 June 2014 - 05:35 AM
I think that the power supply that came with the pod is universal input.  Read the label on it but I think all you need to do is adapt the plug to your standard and you should be good to go.
#3 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9046 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 16 June 2014 - 05:37 AM
The PP2+ doesn't have anywhere near enough available current at the outputs to power the HD500. You could conceivably use the "courtesy output", but that would be the wrong voltage for the US adapter. So, yeah, you'll need to either get the AUS power supply (well, really, you just need the correct insert for the power supply) or a transformer.
#4 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 16 June 2014 - 05:39 AM
the ps supplied with the pod is universal. all you need is an adapter plug.
I'M SO HAPPY!
Also tagged with one or more of these keywords: pod500, pod, 500, power, australia, usa, 120v, 240v, voodoo, pedalpower
