Wifi USB adapter dropping connection
38 replies to this topic
#1 RONBLACK1
RONBLACK1
  • 7 posts
  • LocationCleveland Tn
  • Registered Products:1
Posted 20 June 2014 - 06:28 PM
Hello all. Just got my M20d a month ago. Went to the line 6 store and bought EnGenius USB adapter online. I am able to connect to my iPad but looses connection after 3 or 4 minutes. I have to turn off my iPad and m20d to reconnect only to have it drop out again. I'm only 5 feet from the m20d using my iPad. Any idea why it's not staying connected. I just read some of the other posts. Wow. I paid way too much to the line6 store. Maybe I should have got an apple express. But I thought if line 6 is selling it it's what I need to get. Maybe I need to call them and return it.
#2 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
  • Registered Products:4
Posted 20 June 2014 - 09:40 PM
You are probably experiencing local interference. Have you tried changing the wi-fi channel on the m20d?
#3 RONBLACK1
RONBLACK1
  • 7 posts
Posted 21 June 2014 - 03:29 AM
Yes, I've tried other channels only to have the same thing happen. M20d screen shows still active but my iPad says to check connection on. Wifi I tried 2 other channels as will.
#4 RONBLACK1
RONBLACK1
  • 7 posts
Posted 21 June 2014 - 05:11 PM
Is the airport express the only wifi router that will work with the m20d?
Hate to spend over 100.00 on Apple tech that is already outdated
#5 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
Posted 22 June 2014 - 06:04 AM
Probably anything that will do DHCP will work, but you do need to use the Apple USB/Ethernet adaptor. I would recommend that you pick one that has the ability to shut off the 2.4G and run on only the 5G.
#6 jeanpicasso
jeanpicasso
  • 60 posts
Posted 22 June 2014 - 11:09 PM
I have kind off the same problem. connection drops out and comes back online. The difference is that mine comes back online almost immediately. Its still really annoying tho.
I found that if i "forget the Network" on the ipad, and then reconnect to it, at the beginning of the show, the problem is gone. it comes back the next time im connecting to the Network, but at least i know how to get around it. :)
#7 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
Posted 23 June 2014 - 08:56 AM
I use the "forget the network" button all the time.  iPads just get confused sometimes.
It is almost mandatory if you ever use one iPad with multiple mixers or upgraded software.  Probably not a bad idea to just do it every once and a while.
#8 RONBLACK1
RONBLACK1
  • 7 posts
Posted 23 June 2014 - 03:39 PM
Ok. I'll try to use forget network and get connected again. Will let you know if it helps
Also I've been trying to contact the online store phone # foe customer service. Just cut a recording. I've left several messages today. I've called last week also. I'm thinking I may just re turn the dongle
#9 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
Posted 23 June 2014 - 06:29 PM
Were there contact instructions with the paperwork? The online store is a third party distribution center and not Line 6 itself.
#10 RONBLACK1
RONBLACK1
  • 7 posts
Posted 26 June 2014 - 09:42 AM
Hi dboomer   Yes the package had a cd to use with a pc..  no good for my ipad though.
I was checking online but so far havnt found an answer yet for this problem
#11 jeanpicasso
jeanpicasso
  • 60 posts
Posted 26 June 2014 - 11:39 PM
Did you try the "forget this Network" procedure?
#12 BucF16
BucF16
    Iknowathingortwo
  • PipPip
  • 263 posts
  • Registered Products:8
Posted 01 July 2014 - 07:17 PM
I've had problems with my iPad dropping out with airplay but the M20D app still seems to be working.
Sometimes between sets when I'm just playing music through the PA from my iPad, especially when starting a new song, the iPad Music App will just freeze and quit playing.  Everything else is working but I can't airplay a song to the PA.  Had this happen one gig extensively and then sporadically since.
#13 RONBLACK1
RONBLACK1
  • 7 posts
Posted 09 July 2014 - 06:29 PM
I have contacted support and with their help was approved to return item to the line 6 store.
I decided to get the airport express and apple adapter but was hoping a wifi dongle would work.
I really don't want to chance having connection problems when using the system remotely
Thank you all for your input. I'm very happy with the m20d but still learning my way around on it
#14 RONBLACK1
RONBLACK1
  • 7 posts
Posted 09 July 2014 - 06:34 PM
PS. The videos are very helpful.
Thanks dboomer for your new videos. There really good
#15 stormstudios
stormstudios
  • 29 posts
  • Registered Products:5
Posted 13 July 2014 - 08:15 PM
Sorry for taking this thread in a new direction but Search really sucks and I was not finding what I need. I am asking here because this was on the front page and is semi-related.
I have the Airport Express and the USB-Ethernet adaptor from Apple. I have actually tried two Expresses and neither have worked to set up the wi-fi network. I have tried using with my existing network, creating my own network, and resetting each device to default and trying again. Why is this not working simply? I've tried it multiple times and with multiple Airport Expresses.
Is there a specific model of the USB-Ethernet adaptor that is the only one that works?
I have also tried two different ethernet cables.
I have also tried using my Mac Mini to create a network and Ethernet into that.
No dice.
Can anyone help? I never even get the buttons for '...Existing' or 'Standalone'.
I've spent hours on this simple thing.
#16 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
Posted 13 July 2014 - 09:43 PM
Yes ... you MUST use the Apple branded unit as posted in the FAQ.  The adapter is chipset specific
#17 Digital-sound
Digital-sound
    Iknowathingortwo
  • PipPip
  • 418 posts
  • Registered Products:7
Posted 22 July 2014 - 09:15 PM
The Moshi brand works as well....it is even sold on the apple store online. And, it comes with a USB port, so you can use a USB stick at the same time. I have done it very often. Our backing tracks are on a USB stick, so I can access the backing tracks, connect with my airport express, and record to an SD card.
#18 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
Posted 23 July 2014 - 09:11 AM
Thanks for the tip.  I'll look for one.
I'm sure there are others that work.  The issues is that it must be chip comparable and Apple is the only one officially tested for use.  Don't make the mistake of buying an adapter that says it will work with Apple computers.  That is not the same thing.
#19 stormstudios
stormstudios
  • 29 posts
Posted 24 July 2014 - 07:55 PM
Thanks for the input. You misunderstood my attempt at clarification. Yes, I bought an APPLE one. But there are different model numbers on some of them. I bought the A1277 or something like that. It does NOT work. It's Apple USB-Ethernet adaptor to an Apple Airport Express (as stated above "I have the Airport Express and the USB-Ethernet adaptor from Apple.")
I have tried two different Ethernet cables and no dice.
That sounds really cool actually to still have a USB port available. Thanks for that.
#20 SiWatts69
SiWatts69
    Gear Head
  • PipPipPip
  • 507 posts
  • LocationSouth Yorkshire, UK
  • Registered Products:13
Posted 26 July 2014 - 07:22 AM
Might sound a daft question, but are you plugging into the correct RJ45 socket on the back of the airport express?
Cable needs to go into the LAN port (icon looks like a pair of arrows) NOT the WLAN port (circular icon).On model A1392, it is the RIGHT HAND port adjacent to the USB port.
Complete DreamStage:
M20d with 2x L3m, 2x L3s, 2x L2t & 2x L2m
XD-V75HH & XD-V75BP wireless
#21 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
Posted 26 July 2014 - 04:49 PM
Are you able to create a LAN network between your airport express units and your mini mac?
#22 stormstudios
stormstudios
  • 29 posts
Posted 04 August 2014 - 11:49 AM
Thanks SiWatts and boomer…not daft questions at all. It's always good to start at the most basic and your question helped. I am definitely in the LAN port but my Aiport Express is a 3-4 year old Express that plugs in the wall. It only has a LAN port. It is Wireless 'N' so it's not the really really old ones.
So, is this my issue? I've got to buy the new Airport Express?
I did get a new Ethernet cable to try differently and at least the M20D recognizes that it's plugged in Ethernet. It didn't with the other cable (maybe it's a crossover cable I heard about?).
As for the network with the Mac Mini and the Express, yes that all works perfectly. Why couldn't I just have the Mac Mini create the wireless network? That should work too, correct?
#23 SiWatts69
SiWatts69
    Gear Head
  • PipPipPip
  • 507 posts
Posted 04 August 2014 - 01:34 PM
I posted this to another thread about the airport express. If you've got the M20d as far as recognising it has an Ethernet connection...
Realise you've been through the whole process several times but...
Do a complete HARD reset of the airport express... It may be worth disconnecting your iPad from any other wireless network you have up and running whilst you do this.
1.Disconnect everything except the power from your Airport Express. Press and hold the reset button until you see the status light (LED) start to flash amber rapidly, which should occur after about five seconds.
2.Release the button and the device will reset.
3.Wait about a minute for the base station to finish restarting, then in Settings > WiFi on your iPad you should see an entry for "SET UP NEW AIRPORT BASE STATION" with "Airport Express xxxxxx" beneath where xxxxxx is a sequence of 6 letters and numbers.
4.Once the iPad has initially connected, in AirPort Setup, choose Create a New Network (Recommended)
5.Name your network (the name you enter is irrelevant)
6.Name the device (again name is irrelevant)
7.Create and enter a password. This password is simply the password for managing your Airport Express and connecting to it with your iPad and has nothing to do with the stagescape connection directly.
8.Continue without Internet connection (plug no cables in)
9.Wait til setup completes and click "Done"
10.Plug Network cable to LAN port on back of Airport Express (LAN port has the arrows icon)
11.Plug other end of network cable into USB to Ethernet adapter
12.Power up your M20d and when fully booted plug USB to Ethernet adapter in to the USB port.
13.On M20d screen, press the "i" icon in top right corner of screen and select the "Wi-Fi" button on the left.
14.You should see green text stating "Status: Ethernet connected"
15.On iPad, launch the Stagescape remote app
16.Press green "CONNECT" button in app and you should see a "Choose a StageScape" screen.
17.Press the offered entry and you should get an "Enter StageScape M20d PIN" screen. Enter the pin displayed on the M20d screen.
18.After a few seconds, your M20d WiFi screen should now display "1 Remote Connected" and the iPad should now show your SETUP screen.
#24 stormstudios
stormstudios
  • 29 posts
Posted 05 August 2014 - 01:15 PM
Awesome list SiWatts. Thank you.
I have only had the Green Text (#14) once. I have explored multiple iterations of this list as well.
Following yours exactly I got stuck at #14. It's been spinning for 20 minutes so far looking for a connection.
#25 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
Posted 05 August 2014 - 01:45 PM
The most common mistakes I see users making are:
1. Using a USB/Ethernet adaptor that is not the Apple branded unit specified on the FAQ
2. Plugging into the WLAN port instead of the LAN port (remember you are not looking to connect to the internet)
3. Not fully resetting the Apple Express
If you get these three thing correct it practically sets itself up automatically.
#26 stormstudios
stormstudios
  • 29 posts
Posted 05 August 2014 - 06:36 PM
Are intimating that perhaps I've made another mistake? That's not very friendly of you. It's quite assumptive of a Moderator if you are.
1. Already confirmed I bought the Apple branded unit. ….with a big Apple on the packaging in the Apple section of Best Buy pointed out to me on the shelf by the guy with the Apple shirt who was an Apple brand specialist.
2. The wall mounted Airport Express only has a LAN connector so as much as I might have tried to stick it in a WAN connector that most definitely didn't happen. I mounted my cable to the LAN and had LAN babies because that was the only hole the Church of Steve Jobs was going to allow me into.
3. I fully reset the Apple Express (the one made by Apple) many times.
So, I gave up on the constant resetting of the damn thing as recommended multiple times and followed multiple times…..and voila. The damn thing connected on my old network (without the screen option of Existing or Create New listed in the manual). The resetting of the unit was giving me the problem. Weird. I know. This is one of those times I shouldn't have followed directions.
Thanks for your help guys.
#27 SiWatts69
SiWatts69
    Gear Head
  • PipPipPip
  • 507 posts
Posted 06 August 2014 - 02:13 AM
Hi stormstudios...
I guess where we have crossed wires is that we have (perhaps naturally) assumed you have the 2nd generation Airport Express when what you have is a first generation one which Apple no longer manufacture and which hasn't been manufactured for longer than the M20d has been around. I've no experience with that unit so cannot say that my sequence list is right for it.
Far from not being friendly, I think it is easy to see written comments as personal criticism when they are not intended as such. In my experience, the vast majority of people only want to help.
So, cut us a bit of slack ;-)
Glad you got it working in the end!
#28 eukieb
eukieb
  • 31 posts
  • Registered Products:3
Posted 06 August 2014 - 07:45 AM
Hi, Can someone assist me with this question, My NetGear N600 Wireless Router seems to have died on me. The power supply works but the unit is not booting up. I have decided to buy another Router however, from this feedback forum I realise that the Apple Airport Express (latest model) is highly recommended and I have been using the Apple adaptor out of the M20D. Should I go and get another NetGear Router or is the EXPRESS the way to go. One thing I must note is that there were hardly ever dropouts when I am mixing in crowds with the N600. Does the EXPRESS opereate "line of sight?" which would be a ticket for DROPOUTS?
#29 SiWatts69
SiWatts69
    Gear Head
  • PipPipPip
  • 507 posts
Posted 06 August 2014 - 08:07 AM
I guess it depends how big the range you're operating is.
I'm using the Airport Express (2nd Gen) and haven't had any issues though the venues we've used it in have so far been pretty modest.
The one a number appear to mention frequently is the belkin n600(?) which allows switching off the 2.4GHz band (my express doesn't) leaving just the 5GHz running meaning less interference problems.
#30 eukieb
eukieb
  • 31 posts
Posted 06 August 2014 - 07:05 PM
Hi SiWatts69, thanks for the reply but can you give me a little more clarification?
How " modest " is modest?
Is 50ft away from the Router a range that you still pick up the M20d?
Do you have dropouts when the signal gets blocked by people on the Dance Floor?
Is 2 feet off the ground too low to place the Router and still be able to pick up the signal without interference from people on the Dance floor?
With my old Router I could have accomplished the above without dropouts. I ask these questions to be certain that the " EXPRESS " is the way to go. By the way my friend suggested that I will be more happier with the Apple AIrport EXTREME. What's your take?
#31 Digital-sound
Digital-sound
    Iknowathingortwo
  • PipPip
  • 418 posts
Posted 06 August 2014 - 09:31 PM
I had drop out problems with my apple express when using 2.4GHz mode. In the 5GHz mode, it is solid. It doesn't seem to matter that you can't turn off the 2.4GHz. Just don't connect to it. Be sure to connect to the 5GHz connection which you will have to set up.
#32 SiWatts69
SiWatts69
    Gear Head
  • PipPipPip
  • 507 posts
Posted 07 August 2014 - 02:54 AM
hi eukieb
This is somewhat tainted by how we use it. For our setup, the M20d sits on the opposite side of stage to me, where our guitarist is. He does much of the mixing pre-gig and only a little during a gig.
I, meanwhile am on the opposite side of the stage, with the iPad. He is responsible for unmuting/muting etc at the start and end of sets whereas I'm there to start and stop recordings and adjust our singers' monitors if need arises (I'm a sax player so often have passages where I'm neither playing nor singing). Midway through our first set is a song where I don't play or sing anything so I scurry off stage out to the back of the room and do any quick adjustments that might be necessary. The biggest room I scurried to the back of so far has been a 300 capacity room, about 40m long. My express has never yet (that I know of) dropped out.
From what I know, it is unlikely that people will create difficulties. To my knowledge, the bigger issue is wifi noise, generated by the collection of wifi enabled devices in your vicinity.
Mine lives beneath the mixer in a gator case that the mixer sits on top of. The desk is about 1m off the ground, so the express isn't far from there. A longer network cable in my bag of tricks means I can always move the router somewhere else if I have problems when initially connecting.
I've had zero issues with the express and given its size it's less to lug around, fits neatly in my mics flightcase and is easier to position. Extreme does look like it ought to provide a more stable connection, but that single pro (for an issue I've not experienced) wouldn't be enough to convince me to swap from my express.
#33 Digital-sound
Digital-sound
    Iknowathingortwo
  • PipPip
  • 418 posts
Posted 07 August 2014 - 07:18 AM
If you are on 2.4Ghz, the dance floor, or just a filled venue, will be a problem because almost everyone has a cell phone now, and often, Bluetooth is activated. That can be a problem. I also found that my wireless mic and guitar would be great in soundcheck, and then have many dropouts during performance. That was fixed by using the other mode. It is line 6 gear. Now, nothing gets in the way of my wireless gear, or my 5GHz connection.
#34 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
Posted 07 August 2014 - 07:42 AM
Thanks Digital ... that is the best practice.
Unfortunately you cannot shut off the 2.4G on Apple Express so even though you connect your iPad to it at 5GHz it is still sending and being hit by 2.4G.
#35 eukieb
eukieb
  • 31 posts
Posted 07 August 2014 - 09:43 PM
Thanks Guys for your input especially SiWatts who took the time to address the individual questions. I was fortunate enough to borrow an EXPRESS from my friend and used it at our Gig last night, I am happy to report that it's performance was Exceptional. We had a packed Dancefloor and I worked my way between the crowd and as far back from the mixer approx fifty feet and there was Never a dropout. I am sold on the EXPRESS now, all my concerns were addressed so I will have my daughter FedEx me one from Canada over the weekend. I am wondering if I should buy the EXTREME though which I think has the ability to shut off the 2.5G.
  • 1
#36 eukieb
eukieb
  • 31 posts
Posted 07 August 2014 - 09:49 PM
Just did a double check on the EXTREME, yes, it has more strength but not the ability to turn off the transmitting frees so I will stick with the Express, Thanks again Guys and also thanks to Line6 for creating this Forum.
#37 Digital-sound
Digital-sound
    Iknowathingortwo
  • PipPip
  • 418 posts
Posted 17 August 2014 - 05:56 AM
Does it matter though? I don't know the answer. I just assumed as long as it wasn't getting in between my ipad and the router, it wouldn't affect me. But can it burden the 5GHz just by putting weight on the 2.4GHz?
In any case, my ipad connection was solid everywhere since switching to 5GHz. But, I am not usually far from the board. At a small festival last weekend, I was only doing sound. When too many people got between me and the board, I had dropouts. But the router was in a case, very concealed and behind the stage. Probably an easy fix if I put it even on top of the case....exposed.
#38 SiWatts69
SiWatts69
    Gear Head
  • PipPipPip
  • 507 posts
Posted 17 August 2014 - 06:57 AM
I reckon you've answered your own query there... If it's going to be busy and you're controlling from back of room, raise the express so it is above head height (if possible). Everywhere is different though. Sometimes extra metalwork in a venue can cause issues. RF interference from other electrical devices and so on. The express is a great little router, I like it because it is small/compact and no bits and pieces sticking out of it (aerials etc) but ultimately, it is designed for domestic usage.
#39 HairBear5150
HairBear5150
  • 1 posts
Posted 03 August 2015 - 06:11 AM
I've got the M20d.
Tried with Apple adaptor and tplink router. Works ok for 2 mins then drops out.
Bought the Cisco lynksys ae1000 as recommended and it does the same thing.
I use 4 line 6 wireless mikes. Can these interfere?
