Do you use the pre- or full ampmodels?
6 replies to this topic
#1 tormod1
tormod1
  • 40 posts
  • Registered Products:3
Posted 28 June 2014 - 01:59 PM
What sounds the best in your opinion?
I use the DT25, with two cabinets, and is STILL looking for that sound in my head....
#2 DarrellM5
DarrellM5
    Gear Head
  • PipPipPip
  • 929 posts
  • LocationRound Mountain, NV
  • Registered Products:5
Posted 29 June 2014 - 12:05 AM
I use the pre models when running to the DT25 with the Line6 link.  Otherwise It would be modeling an amp and then sending it to my amp, which would also be trying to model an amp.
I use the full amp models when going into the effects return of my Vetta II and I would also use them if I were going out to a Stagesource speaker or PA.
#3 Tboneous
Tboneous
    Gear Head
  • PipPipPip
  • 694 posts
  • Registered Products:8
Posted 29 June 2014 - 09:26 PM
My go to is pre models when running my DT-50 via L6. I also don't use cabinet models or mic simulation. On single amp patches, I center the mixer and on dual amp patches I pan about 30% L & R.
That's me trying to sound like me. If I am trying to sound like someone else, I might approach it a bit different. (But not by much I would imagine)
Click Here To Support Complete DT and Helix Integration!
#4 jegler
jegler
    Iknowathingortwo
  • PipPip
  • 134 posts
  • LocationThe Basement
  • Registered Products:6
Posted 13 July 2014 - 08:41 PM
I use full amp HD500 and LVM on the DT25.
Pre's on the HD500 into full volume DT is just too frikken loud and squirrely for me.
Maybe when I retire out to the country, I'll take the time to iron out some full vol patches, but for now it sound pretty good.
www.redlightrecords.com
#5 Zilthy
Zilthy
  • 18 posts
Posted 15 July 2014 - 03:36 PM
As jegler does, I use the full amp HD500 in LVM.   In normal mode, I use the pre- models.
#6 wicker_man
wicker_man
    Iknowathingortwo
  • PipPip
  • 102 posts
Posted 16 July 2014 - 09:52 PM
I mainly use preamp models without cab and mic simulation when using my DT25 head and 2x12 cab. Occasionally I'll use a full model, but will still disable cab and mic. I never use LVM now, since the POD firmware update that improved the master and channel volume interaction with DT amps.
#7 MartinDorr
MartinDorr
    Iknowathingortwo
  • PipPip
  • 465 posts
  • LocationArizona, U.S.A.
  • Registered Products:4
Posted 17 July 2014 - 08:47 AM
Always preamp models (1, 2, or no preamp at all).
All HD internal signal levels <= -12dbFS (checked via USB with HD master at 100%)
HD cab and mic models to taste (they are just hardwired EQ/compression models).
HD master to adjust volume to venue (around <=50% for home).
DT master usually at 2-3pm, sometimes higher, never less.
