Setlists, Banks, And Abcd Strategies
setlist banks patches presets abcd fx
41 replies to this topic
#41 robertmcollins3
robertmcollins3
  • 83 posts
Posted 17 November 2014 - 09:29 AM
I don't play nearly as much as most of the above and my sets/gigs aren't nearly as long, but for what it's worth I find the FS5-8 mode much easier to work around. But really it's obviously whatever works best for you.
FS1 - Vol Pedal
FS2 - Compressor
FS3 - Noise Gate
FS4 - Reverb
FS5 - Delay 1 (dotted 8 plus 1/4)
FS6 - Delay 2 (1/4 modulated)
FS7 - Overdrive (screamer)
FS8 - Empty since I use two delays on FS5
This isn't the order of the chain, just the FS.  FS1-4 are usually always on, and I set the bottom switches to things I will usually turn on/off like delay and overdrive.  I just use one amp/cab/mic combo and feel it works best for most situations (Vox AC30 with Blackback 30, 57 on axis mic).  This would of course not be a good setup for metal though.
#42 line-6-user
line-6-user
    Iknowathingortwo
  • PipPip
  • 238 posts
  • Registered Products:4
Posted 08 December 2015 - 05:29 AM
I do not organize my patches. They get put in slots as they are created. The reason for this......I use an app for the iPad called set list maker. http://www.arlomedia.../main/home.html it allows you to catalog your songs and then put them into set lists. One of the attributes of the Song is a midi command that you can create that will select the patch you want on your pod.
So, with my iPad in place. When ever I touch the song in the setlist it selects the patch. So, I have ultimate flexibility.
Can you share the information on what you are using for connecting SLM with the HD500, as o am having problems using a standard MIDI to USB cable.
I think that set list maker is the way forward to keep patches easy to find for all gigs.
Here is my first attempt on creating a patch for "Another Brick On The Wall".
http://line6.com/cus...ne/tone/220305/
http://line6.com/cus...ne/tone/220306/
http://line6.com/cus...ne/tone/220304/
Also tagged with one or more of these keywords: setlist, banks, patches, presets, abcd, fx
