PODxt Live no output
11 replies to this topic
#1 Putzherr
Putzherr
  • 5 posts
Posted 02 July 2014 - 01:08 AM
I have bought a used xt Live that seems to work fine except I can't get any sound out of it, either through headphones or my amp. Not a beep.
At first I thought it could be because it came with a non standard power adapter rated at only 500 mA, so I went out and got a replacement capable of the the required 2 A, but no luck. :-(
What do you think? Should I return it?
#2 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
  • Registered Products:8
Posted 02 July 2014 - 03:57 AM
Was it working when you bought it? Sometimes the little sliding switch on the back by the jacks (IIRC pad?) can get bumped and be in an inbetween position causing this. Other than that I wouldn't take anything apart as you might not be able to return it afterwards.
-B
Smell the glove.
#3 Putzherr
Putzherr
  • 5 posts
Posted 02 July 2014 - 04:08 AM
It was like this when I got it. I have tried flipping the Norm/Pad switch, adjusted the "level" knob and everything else I can think of. No sound.
I know it gets my guitar signal though, since the built in tuner function registers it.
#4 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
Posted 02 July 2014 - 04:43 AM
Well assuming it actually worked when you bought it. Sit down with the manual.
Check to make sure the output knob in the back is set on something other than zero. Try running an mp3 player in the jack. Check the channel volume settings.
Other than that it could be bad output jacks, they do crack at the solder joints.
Smell the glove.
#5 Tinyfireball
Tinyfireball
  • 7 posts
  • Registered Products:10
Posted 02 July 2014 - 05:29 AM
Hi,mаке anew calibration to volume pedal , such can be.
#6 Tinyfireball
Tinyfireball
  • 7 posts
Posted 02 July 2014 - 05:32 AM
Or press SAVE once, use the select key to scroll clockwise to “factory recall” page, then press SAVE twice.
#7 Putzherr
Putzherr
  • 5 posts
Posted 02 July 2014 - 05:41 AM
I bought it just a couple of days ago on a pawn auction. I don't think I have done something to mess it up, so quite possibly it was broken when I got it.
Anyhow, thanks for all tips and suggestions. I haven't tried calibrating the pedal. Will try that when I get home, aswell as the "factory recall" thing.
Thanks!
#8 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 02 July 2014 - 05:42 AM
is the power supply ac or dc output? should be 9vac
I'M SO HAPPY!
#9 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
Posted 02 July 2014 - 05:46 AM
All good tips.. you can try to reflash the memory as well - but save that one for last.
Be sure to nab the Line 6 Monkey in the DL section.
Smell the glove.
#10 Putzherr
Putzherr
  • 5 posts
Posted 02 July 2014 - 07:31 AM
Forgot to mention, the MP3 player in the AUX-in was the first thing I tried when I couldn't get any sound from my guitar.
Pedal calibration had no effect, and yes the power brick puts out 9V AC 2000 mA. (it's not the original though, I didn't get one.)
I think I'll pass on the reflashing thing. It's got v3.01 now, and does that monkey thing even run on Win8.1 64 bit?
Most likely I'll return it tomorrow, it seems broken to me.
Thanks for all the helpful tips though.
Cheers!
#11 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
Posted 02 July 2014 - 08:42 AM
Hey one last thing. Fire it up, put the pdal toe down, trim pot mid way - plug your guitar in with the amp on. Turn the volume up on the guitar and while the strings are vibrating wiggle the plug in the XTL's ouput jack. If there is a pcb crack "sometimes" this wiggling will close the gap and sound will come out.
Slim hope but if everything else failed it can't hurt.
Rock On!
Bill
Smell the glove.
#12 Putzherr
Putzherr
  • 5 posts
Posted 02 July 2014 - 12:35 PM
Tried that, still nothing. I'm giving up on this now. It's going back.
Many thanks though for all the support!
