Line 6 driver conflicting with my other driver?
4 replies to this topic
#1 BaylorPRSer
BaylorPRSer
  • 4 posts
  • Registered Products:1
Posted 02 July 2014 - 06:23 PM
So I want to use gearbox on my pc and adjust the tones for my pod x3 on my pc. The problem is that whenever I have the usb hooked up to both my interface and the pod, it doesn't work. I need the interface to power my monitors and just want the pod connected so i can tweak tones. How do i set that up?
#2 BaylorPRSer
BaylorPRSer
  • 4 posts
Posted 04 July 2014 - 05:04 PM
#3 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 07 July 2014 - 07:35 AM
windows or mac?
the general thing you need to do is make sure your operating system is still setup to use your preferred interface.
it may not be possible, as i cant recall if gearbox will allow routing over a non-line6 interface... but i'd check the OS settings first.
#4 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2576 posts
  • LocationNew England
  • Registered Products:3
Posted 08 July 2014 - 03:58 AM
In general, PCs only allow one audio device (and its drivers) at a time.  You might be able take the audio output from the Pod to the audio input of your interface to drive the monitors (as in direct input monitoring).
#5 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
  • Registered Products:6
Posted 08 July 2014 - 06:14 AM
On some machines you may be able to use a USB audio interface while only controlling the PODX3 via USB.
