Sudden Volume Changes on Certain Patches
hd500 dt50
5 replies to this topic
#1 moogary
moogary
  • 82 posts
  • LocationToronto, ON, Canada
  • Registered Products:4
Posted 03 July 2014 - 07:39 AM
Over the past couple of weeks, I have been having some problems with a couple of patches.  I would select a patch and it would be at a very low volume (all my patches were previously leveled).  All other patches except are at the correct volume.
I have flashed the firmware and re-installed the set to no avail.
I did notice something weird.  If I double click one of the 2 patches in HD Edit, the volume increases to normal level.  If I change away from the patch using the foot switches and come back to the same patch, it is low again.
Anyone have any insights to the problem?
  • 1
#2 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2271 posts
  • LocationU.S.A.
  • Registered Products:16
Posted 03 July 2014 - 08:42 AM
I had this same problem some time ago. while I was setting the levels in the mixer in the GUI. Also, it happened with the pod reset & calibrated. All I could come up with was somehow that patch got corrupt. So I uninstalled the drivers and HD500 Edit with Line 6 uninstaller, restarted the computer (Win 7) then reinstalled the drivers and HD Edit. reflashed (not saving presets), reset, recalibrated and after that I was good.
  • 1
#3 moogary
moogary
  • 82 posts
Posted 03 July 2014 - 08:51 AM
Thanks Hurghanico & Brazzy.  I will try to reset tonight.  Good idea.  However, the reason I re-flashed was because I was getting these issues in the first place.  Will keep you posted...
  • 1
#4 moogary
moogary
  • 82 posts
Posted 03 July 2014 - 07:20 PM
Well the Reset certainly did help some other problems I had such as correct the FS6 not working (I had to rearrange my banks without FS6).  The volume levels are more consistent now.  I re-leveled one patch and all seems to be good for the moment.  I have a gig tomorrow night and I don't trust the POD at the moment.  Hopefully all will go well as usual.
Thanks so much for the suggestions.
  • 1
#5 moogary
moogary
  • 82 posts
Posted 05 July 2014 - 04:08 PM
Well... It didn't go very well.  When I did a sound check at the gig last night, my FS6, Bank down and Volume pedal all were not responding.  I flashed the memory again, performed a System Reset like last time, but the POD didn't return to a functional state.  I had to use channels A and B on the DT Amp to have a Clean and Dirty sound with no effects.  Bummer!
I brought the POD today to a repair center and hopefully they can fix it.  VERY unreliable for gigging.
#6 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2271 posts
  • LocationU.S.A.
Posted 05 July 2014 - 05:46 PM
Thanks for the update, I've never experienced foot switch issues. I hope you get it fixed bud. Some people gig with them ok. I don't gig with it......yet. I just use them at home for recording my own stuff.
Also tagged with one or more of these keywords: hd500, dt50
