Suggestions For Keyboard/mainstage Thru Hd500/dt25
3 replies to this topic
#1 karmicfreak
karmicfreak
  • 92 posts
  • Registered Products:4
Posted 06 June 2013 - 05:00 PM
Hello,
I am playing in a band where I'm splitting my time between playing guitar and keyboard, while singing lead.  I'm using a keyboard controller through Mainstage on my MacBook Pro, and want to be able to use my HD500 to control volume on the keyboard.  Here's the solution I've come up with, and a plea for advice from anyone else who's done this:
I am using separate patches for keyboard and guitar.
For guitar, I am using my JTV-69 with the Variax digital cable
For the keyboard, I'm taking my MBP 1/8" output to the 1/4" guitar input on the HD500.
L6 Link sends the signal to the DT25.
My questions:
Recommended amp for the keyboard?  I usually default to the Blackface Twin, but I'm not quite sure it's the sound I want.  I know I can't use NO amp model if I'm outputting thru the DT25.
Will I get interference issues when playing guitar if I turn down the keyboard volume, and vice versa?
Is there another "best" way to do this?  Maybe plugging the keyboard into the DT25 directly will give a better sound, although it would stop the volume pedal from working?
Thanks for any ideas.
#2 Rewolf48
Rewolf48
    Power User
  • PipPipPipPip
  • 1236 posts
  • LocationUK
  • Registered Products:6
Posted 07 June 2013 - 05:02 AM
There aren't many here that will be able to help with this, but I might be able help with some aspects or trigger an idea or two by describing what I do.
I play a JTV-69 (VDI) and (second) keyboards in our Prog Rock band, and my keyboard sound is routed through my HD500 so we have some similarities, but there are also differences which will limit how much advice I can give:
1) I don't have a DT25 - instead I use the XLR outs to either 1 or 2 FBT Maxx2a FRFR powered speakers that can be backline or monitors with XLR daisy chained to PA if the gig is big enough.  So I can't help with the DT25 specifically
2) I don't have a Mac or MainStage - instead I have an ASUS laptop (touchscreen) running windows 8 and I use Bloxpander as a VST host.  So I can't help with any specifics on the software side.
For keyboard heavy songs (Watcher of the Skies) I have a dedicated Keyboard patch, for songs which are guitar only (Aqualung) I have a dedicated Guitar patch that gives me the 3rd fret virtual capo on the acoustic patch.  For other songs however such as Echoes I play part Keyboard and part Guitar using a single patch.
My keyboard is an old Korg N364 which I primarily use just as a controller, but also have patches on it where I haven't yet got a VST equivalent so it is part primary instrument and part backup should the laptop fail.
I take MIDI Out from the N364 into the MIDI In on the HD500 and then set the HD500 to MIDI Through - so it merges incoming MIDI with internally produced MIDI and sends it all out of the HD500 Midi Out/Through which is connected to the MIDI In of the Laptop (USB Midi adaptor).  The Laptop MIDI Out is connect to the N364 MIDI In, but generally nothing is sent down this.  The N364 doesn't pass MIDI In through to MIDI Out so there is no loop.
Audio signals go as follows: JTV into HD500 using VDI, N364 in stereo via two 1/4" Jacks to HD500 FX Loop Returns.  HD500 XLR outs to FRFR speakers.
What about the Laptop sounds? well that is USB - ASIO drivers on the laptop send the sound directly to the HD500 Audio Outs - however if this doesn't work Plan B is 1/8" headphone out on Laptop split to 2 x 1/4" into the FX Return and Plan C is 1/8" into HD500 MP3 input.
So how do I control Keyboard Volume?
There are two methods depending on which audio feed I have:
a) If it is the N364 feed I have the option of controlling the FX Return level with the Expression Pedal (or can preset it on the patch), you could add a volume pedal after the FX Loop, but the FX Return is just as easily controlled as the Volume pedal, (method b also works here just as well)
B) if it is the USB Audio feed I have no control within the HD environment as the USB Audio is fed in after the HD Audio processing (only the Master volume knob works), but I simply control the volume by setting the expression pedal on the HD500 to transmit MIDI cc07 data (volume).
This is on channel 16 against which the master volume of the VST host is linked - the individual sounds are on channel 1, so basically Ch 1 is used to control the Instruments including sometimes cc07 to crossfade between sounds, while Ch 16 is used to control the Host.
I use Ch 16 Note messages to change sub-scenes in the VST Host and at the moment only have a single Patch (Scene) but control which of the VSTi receive which aspects of the MIDI on Ch 1 by switching between predefined configurations in the Host.  This sounds complex, but basically the VSTi are all active all of the time, I just switch the MIDI routing around them to define what VSTi gets sent the Note On messages at any time - they all receive Note Off messages all of the time which is important if you want to avoid the hanging note problem.
The Note messages to change Keyboard sounds could just as easily be Patch Change or Continuous Controller messages and they are sent by adding MIDI messages to the foot switches on the HD500 - I set the Host to ignore the HD500 generated Patch changes because I don't want the keyboard patches to change as I change guitar patches,
I use the top row of switches on the HD500 to switch on and off Guitar effects, the bottom row to switch keyboard patches and have the HD500 in pedalboard mode so I have to hit the up/down switches to change patches.  I also have a second Expression Pedal connected which acts as the main volume control with the Expression 1 controlling effects.  The latter can mean that when I need a big keyboard fade in or cross fading between sounds, that I have both expression pedals controlling Keyboard volume - but one controls the master volume of the VST Host (my main level) while the other controls the volume of the individual VSTi instruments.
Back to your questions:
I honestly don't know - I do sometimes put the N364 through an Amp model, but that is mainly a clean Hammond sound into a Marshall in order to get that authentic Deep Purple distorted Hammond sound.  Pick the cleanest and flattest that you can - you could try the Hiwatt which might not have been an obvious choice, but was intended to be very clean when it was first produced.
It may be that the FX loop trick placed after the Amp model (so the Amp model has nothing going into it) will work quite well as this avoids any Pre-amp modifications to the Keyboard sound.
You shouldn't - the inputs into the HD500 are isolated from each other and you can select which inputs are active at any time on a patch by patch basis.
Using MIDI will allow you to control the volume this way, other than that I wouldn't say that there is a "best" way, just a whole load of options that you might try to see what works best for you.
#3 Rewolf48
Rewolf48
    Power User
  • PipPipPipPip
  • 1236 posts
  • LocationUK
Posted 07 June 2013 - 05:12 AM
B) = b )
#4 karmicfreak
karmicfreak
  • 92 posts
Posted 09 June 2013 - 03:45 PM
Thanks for the detailed replies - I appreciate you sharing you knowledge, Rewolf!  I'll tell you what I've found so far, and what I've done to be able to control everything satisfactorily.
First, I found the least offensive amp for keyboard (piano, suitcase, wurlitzer, organ) reproduction seems to be the Class-A 30 model, with the DT25 set to Triode (rather than the default pentode) mode.  There is very little hiss/noise, I've dialed out distortion and fuzz I was getting with the blackface models, and I've thrown in a noise gate, turned down to 10% for silencing it when I'm not playing.  Also, I set this patch to only take the Guitar In, which I've plugged my keyboard into.
Likewise, I usually keep all patches at Guitar + Variax inputs, but I've taken the patches I'm using at this gig for just Variax, so I don't have to turn down the keyboard when I switch to guitar.
Finally, I did replace the crapola Casio keyboard I was using as a simple MIDI controller with a new Novation Launchkey 61, which has a ton of adjustable faders, dials, and pads.  I am controlling the laptop's output volume in Mainstage from the keyboard itself now, and it's working well.
I may venture into the deeper MIDI editing you have introduced me to as I use this rig for more gigs.  Thanks again!
