DL-4 Static/white noise
2 replies to this topic
#1 beedoola
beedoola
  • 3 posts
Posted 04 July 2014 - 07:28 PM
Has anyone found out what causes this? I'm not going to spend $100++ to have the pedal repaired. I can do it myself, if someone can just point me in a direction as to where the component(s) that are failing and causing this may be. I've seen many other posts on the web about this issue with white noise and static, and how it can abruptly occur.
Thank you.
#2 dk_DL4
dk_DL4
  • 1 posts
Posted 19 August 2014 - 08:42 AM
I have a similar or identical problem. Not a lot of details offered with the original post.
My DL4 lost the "MONO" channel, which I use most often, since I play thru a single amp. It produces a white noise hiss. I've been using the "R" channel, but would like to repair.
Anybody have an insight on this?
#3 sidesmusic
sidesmusic
  • 2 posts
  • Registered Products:5
Posted 15 January 2016 - 12:00 PM
I had the same problem with my DL4, hiss / loud noise when the effect was activated so true-bypass (alternate is always present) connected mono (L input / output L). With a cable disconnected on R output the hiss disappeared. I cleaned pcb and all components with the spray and checked the solders and they were good but the problem remained. I kept turned on the unit for more than several hours at a time (do not remember if 18 hours) and the hiss / noise disappeared and is no longer returned also connecting in mono (L in / L out). I have no idea why this worked but it's what happened to my DL4. I hope it can be useful.
