UX2 power supply without pc
4 replies to this topic
#1 NkMorg
NkMorg
  • 1 posts
  • Registered Products:1
Posted 06 July 2014 - 12:05 PM
hey@all! hope, this is the right place for my question - if not, please shift the topic ;)
i've got a L6 UX2 for some weeks now and have a question to the power-supply.
since it is not allowed to put the UX2 to an USB-hub (at least the manual says so), i've got a problem with the power-supply of the UX2: I use it for listening music as well, and my PC uses to go to the standby then - but then the power-suppy for the UX2 fails and the UX2 turns off.
I've tryed to set the standby in that way that it supports the USBs with power even if it's in the standby, but it did not work :(
furthermore it would be great to be able to use the UX2 for listenting to music from the mp3-player as well, whats theoretically possible with the right cables, but would be nonsense if i would have to have the PC running all the time.
So: Is there a possibility to support the UX2 with power independently from the computer?
thanks in advance and all the best
Mo
#2 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 6967 posts
  • Registered Products:6
Posted 06 July 2014 - 12:22 PM
Short answer: You can not use the UX2 without a computer.
It is a USB Audio interface for your computer. The computer does all the processing.
#3 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 07 July 2014 - 07:41 AM
you can try a powered usb hub...
the key thing is that it's not supported... however that doesn't mean that it won't work....
just means that line6 won't be able to assist you if there are issues....
#4 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 6967 posts
Posted 07 July 2014 - 07:46 AM
They can work with a powered hub, in conjunction with a computer, and on some machines it works properly with a hub vs the pc's ports.
But I think the OP was wanting to use an mp3 player with just the UX2 and a powered hub and no pc.
#5 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
Posted 07 July 2014 - 07:49 AM
true... even with a powered hub you'd need the computer on.
