drbilldc Posted July 7, 2014 Share Posted July 7, 2014 I'm trying to install a deluxe Electric mistress in the effects loop of my HD 500. I'm getting very little of the Mistress's effect coming thru. I've played around with the send and receive levels and the mix on the HD edit. I can her slight Flanging effect but nothing close to what the 's capabilities are. on the POD: Send-->guitar in on the pedal. "flanged out on the pedal--->return on the HD 500 Any Ideas? Bill Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 7, 2014 Share Posted July 7, 2014 What do you have the mix parameter for the loop set to? You'd want it set to 100%. Quote Link to comment Share on other sites More sharing options...
drbilldc Posted July 7, 2014 Author Share Posted July 7, 2014 yeah mix was at 100% when I initially set the loop on the edit. Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 7, 2014 Share Posted July 7, 2014 Have you tried using it without being connected to Edit? The other thing is where do you have the stomp/line switch for the loop set for on the HD500? Also, are you using just one output on the pedal or two? Quote Link to comment Share on other sites More sharing options...
drbilldc Posted July 7, 2014 Author Share Posted July 7, 2014 yeah just one output and i'm running back into the POD on the LEFT effects return (mono), I used line and stomp. No I haven't tried without it connected to editor. I'm going to go at lunch to a music store and hook up the pedal to an amp and see if it is the pedal itself. I'd use my DT 25 but i blew the tubes playing on a float Friday hooked up to a generator but that's a whole other thread Quote Link to comment Share on other sites More sharing options...
drbilldc Posted July 7, 2014 Author Share Posted July 7, 2014 It's not the Electric misstress, she's flanging properly. I went and plugged it in to another amp. Quote Link to comment Share on other sites More sharing options...
juicyjones Posted July 8, 2014 Share Posted July 8, 2014 You switched the Effects return on the HD500 from "line" to "stomp," yes? Quote Link to comment Share on other sites More sharing options...
