Pod Hd 500 - Tuner
9 replies to this topic
#1 Raphael26
Raphael26
  • 52 posts
  • Registered Products:1
Posted 07 June 2013 - 10:12 AM
Hello,
Someone can help me with hd 500 tuner?!
I think it is unregulated, cause if i put Db, hers sounds like D.
Someone know how regulated the tuner??
thank u all!!!
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16062 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 07 June 2013 - 11:13 AM
The tuner has a calibration knob (A=440, etc.....) but it is a chromatic tuner. If you want Db, tune down from D until the display shows Db.
.... John Lennon
#3 Raphael26
Raphael26
  • 52 posts
Posted 07 June 2013 - 11:31 AM
but when i tune Db, the displays show me correctly Db, OK is perfect.
But sounds like, D. The displays doesnt are ok. I think this would be regulated, or no?
#4 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16062 posts
Posted 07 June 2013 - 11:32 AM
Check that the tuner is set to A=440. Also check that your reference is correct (whatever it is that makes you say the HD 'sounds like D').
.... John Lennon
#5 Raphael26
Raphael26
  • 52 posts
Posted 07 June 2013 - 12:02 PM
Ok dude!
I'm a recent user of HD 500, do you know where i found the menu to setup "A=440" ?
#6 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16062 posts
Posted 07 June 2013 - 12:05 PM
When the tuner is engaged the display screen will show the current calibration in Hz/Frequency. Turn the little black knob (I think it is knob#1)to change it.
.... John Lennon
#7 Raphael26
Raphael26
  • 52 posts
Posted 07 June 2013 - 12:09 PM
Right, i'll try! Thank u, dude, very much!
Can i remedy some questions in a chat w/ u? I wanna know a little more about HD500. It's possible?
#8 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16062 posts
Posted 07 June 2013 - 12:14 PM
Post your other questions in a new thread here. That way you will get the benefit of many users' ideas and opinions.
.... John Lennon
#9 Raphael26
Raphael26
  • 52 posts
Posted 07 June 2013 - 12:18 PM
Ok!
I'll play this weekend in a stage, but i can't found a distortion like deftones.
In really, i dont get create any distortion :/
Do you have some tip, some guidance?!
#10 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16062 posts
Posted 07 June 2013 - 12:28 PM
There's a link at the top of this page (and every webpage here) to a site called Customtone. This is where Line 6 users can post their presets/tones to share with others. Select the HD500 as the product, and enter 'deftones' in the search panel. Download the tones that yopu want to try out, load them into HD500 Edit, and audition them. If you want to save them to your HD500 device, use the SEND SELECTED command in HD500 Edit.
Just be aware that these tones are not 'screened' in any way. What someone else thinks sounds like deftones may not sound right to you. But often they can be good starting points for tweaking.
.... John Lennon
