HD500 with L6Link to L3t?
5 replies to this topic
#1 randychesbro
randychesbro
  • 24 posts
  • Registered Products:4
Posted 10 July 2014 - 05:16 PM
Im having a little trouble with having the L3t connect to my HD500 using the L6Link. I did go purchase a data/dmx cable for it today but ended up with the same issue as when using a good mic cable..
Is there a step by step process I need to do to have it connect every time? it seems random.  If i turn off the HD500 to reset it and back on it doesn't connect to the L3t I reed turning them off and on but no go.  If i leave it off for a bit and then on it connects. I worried that if I'm out giving and the power goes off or whatever happens then I can start back up and running quickly.
anyways if there is a process I need to do to have them connect every time please let me know.
side note.  If I go xlr out of my Hd500 can i go to the line input at the top where the rca inputs are? I know it works but its way lower volume.
am I not supposed to do that?
thanks
#2 Tboneous
Tboneous
    Gear Head
  • PipPipPip
  • 694 posts
  • Registered Products:8
Posted 10 July 2014 - 08:40 PM
Are you turning on the pod first, letting it finish booting and then turning on the L?
Click Here To Support Complete DT and Helix Integration!
#3 zaphodboy
zaphodboy
    Iknowathingortwo
  • PipPip
  • 229 posts
  • LocationManchester, UK
Posted 11 July 2014 - 12:40 AM
I use a DMX cable to run from my HD500 to an L3m. First I turn on the pod, let it boot then turn on the speaker. I don't know if there is an 'official' order to boot them but this works first time, every time for me.
Good luck.
#4 randychesbro
randychesbro
  • 24 posts
Posted 11 July 2014 - 08:24 AM
Maybe I wasn't waiting long enough. I guess i figured it would recognize it like USB, plug it in and it see it.
Another Question. If i go into the L3t inputs It sounds like I plugged into a sound board directly with all the high end nasty grit. is there a setting I need to change?
thanks
#5 Tboneous
Tboneous
    Gear Head
  • PipPipPip
  • 694 posts
Posted 11 July 2014 - 03:25 PM
You may need to change your output settin on the HD.
#6 zaphodboy
zaphodboy
    Iknowathingortwo
  • PipPip
  • 229 posts
Posted 11 July 2014 - 11:28 PM
thanks
Again, I'm not sure what the L6 official settings are supposed to be but I have mine set with the POD in 'studio/direct' and the L3 in 'electric guitar' mode. To my ears this gets rid of all the nastiness.
