How to set up your computer to get the pod farm sound to your computer speakers (Windows 7)
windows 7 computer speakers pod farm
7 replies to this topic
#1 Fantaghir0
Fantaghir0
  • 3 posts
  • Registered Products:1
Posted 10 July 2014 - 11:34 PM
I was searching on how to set up my PC sound options to using my PC speakers instead of a headset plugged into the pod (in my case POD Studio GX).
My friend who recomended this hardware to me said he has it set up this was, but didn't remember how.
So I searched the manual, the knowledgebase and the forum but found nothing. I called the hotline and while waiting, the recorded voice told me, that the line 6 pods can not do what I wanted, not without a cable connected from the headset jack to the line in of the soundcard in the computer.
As I am using a 5.1 soundsystem, that "line in" is used as one of the "line out" to the soundsystem, so that's not an option to me.
But I didn't let myself be discouraged and finally I found the option I was looking for!
First make sure, you set up the software as recomended, so you have sound via the headset plugged into the pod. Don't tweak around before you have that, or you will never find out, where the problem is.
Now go to your Soundsetup in Windows (7 in my case) and select the pod as standard recording device. Open it's properties and select the second folder (I'm sorry, my windows interface is german, there it's called "Abhören" which should translate as something like monitoring)
and check the box next to "use this device as playbacksource" (again aproximatly translated)
Maybe someone would be so kind and answer with the correct english windows terms are, or what to select in other windows/mac/whatever versions.
#2 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
  • Registered Products:6
Posted 11 July 2014 - 04:51 AM
The correct configuration is to connect your monitoring solution directly to the GX.
There are workarounds.
What surround do you have?
#3 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 11 July 2014 - 05:14 AM
might work for your windows sounds... won't work for a recording software... as that will require ASIO drivers... and that will require that you use the GX out.
#4 Fantaghir0
Fantaghir0
  • 3 posts
Posted 11 July 2014 - 03:29 PM
ehm... i just started learning to play the guitar yesterday! and as such I am not (yet) interested in recording - maybe for educational purposes to hear what i did there :).
So I only wanted to hear what I play without using headsets and without crawling under the table everytime to switch my logitech 5.1 speakers from computersoundcard to the GX out. Probably not the best soundquality but this way it works fine for my purposes.
I think this is a nice solution for beginners, to take the first steps without buying an amp a.s.o. but using the computer n stuff we allready have.
#5 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
Posted 12 July 2014 - 04:48 AM
just plug headphones into the gx for now.
hopefully you will get hooked, and a couple years from know you will have a set of monitors and a small (or not so small) mixer.
Happy riffing!!
#6 Fantaghir0
Fantaghir0
  • 3 posts
Posted 12 July 2014 - 06:16 AM
thx :)
just played the first few notes in rocksmith 2014 and it allready sounds like music... sort of :)
I use the headphones this way, I was just looking for an alternative to maybe impress my neighbours (if they want to or not!) with my caterwauling and posted the setup I found here to share it with other newbies.
#7 saphetiger
saphetiger
  • 1 posts
Posted 14 August 2016 - 02:13 PM
If you can't monitor the signal from the UX2 to the PC, can you send the PC sound to the UX2 so you can actually hear the mix?  It seems counter intuitive that there is on way to hear what you're playing and the rest of the track through the same speakers.
#8 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
Posted 15 August 2016 - 11:19 AM
Yes, all your pc sounds, including your DAW, are routed to the UX, it becomes the soundcard.
Also tagged with one or more of these keywords: windows 7, computer speakers, pod farm
