Update Firmware
2 replies to this topic
#1 krychou
krychou
  • 1 posts
  • Registered Products:1
Posted 11 July 2014 - 02:19 AM
I received a JM4 looper recently and i wanted to save rec mix as wav to card but it didn't work... so i updated the Firmware 2.09. I tried many times but the update doesn't progress to 100%. Each time that stops around 93% or 15% and that fails... Someone has an idea because That makes me crazy!
Thks guys!
Krychou
JM4 looper
Firmware DSP 2.07 / MCU 1.05
Transcend SD card 2 Go
  • -1
#2 fazz1957
fazz1957
  • 2 posts
Posted 17 February 2015 - 12:20 AM
if you are trying to save from your computer you need to save you file as PCM 16 BIT 44100HZ MONO or it will not play
  • 1
#3 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2329 posts
  • LocationU.S.A.
  • Registered Products:17
Posted 17 February 2015 - 06:27 AM
Thks guys!
Krychou
JM4 looper
I know this system is finicky with the kind of card you use and you should format the card with the JM4, put it your computer and move the bin file in the right place on the card and it should go.
This is good info but wrong subject. I think but maybe I'm not undestanding the OP correctly. Sorry if I'm wrong. Don't take it personal. :)
Edited by Brazzy, 17 February 2015 - 06:32 AM.
