Podfarm Badly Distorting Reaper Tracks
5 replies to this topic
#1 liccc96
liccc96
  • 1 posts
  • Registered Products:1
Posted 24 April 2013 - 05:49 AM
Apparently i messed up and created a topic on the older forums, which are now read only so i will repost my question here.
"Hello everyone.
I'm having a really annoying problem with the Pod Farm plug-in right now. I'm using an UX1 with the 32bit version of Reaper on Windows XP. Basically when i use Pod Farm as an effect for a track the sound becomes heavily distorted and messy, with crackling and popping. Note that this doesn't occur when i'm using the standalone version of Pod Farm. It worked perfectly at first, but started doing this one day out of the blue. I'm not clipping the input, neither the output before or after adding the effect. What could be the source of this problem? Any advice?
Thank you in advance!
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 24 April 2013 - 07:31 AM
you probably have monitoring turned on in reaper (its either an M icon or a speaker icon on the track forget which)
but this might double up your tone and result in the mess you're hearing.
#3 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
  • Registered Products:6
Posted 24 April 2013 - 08:27 AM
Are you adding the plug-in to a dry track?
Are you meters in Reaper in the red on playback?
Have you tried dialing back the input of the plug-in in POD Farm (upper left in the GUI)
#4 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2576 posts
  • LocationNew England
  • Registered Products:3
Posted 25 April 2013 - 05:11 AM
Crackling and popping may indicate that your CPU usage is too high - select CPU usage view and check it while playing back the problem project.  IF you have a lot of CPU-intensive tracks going at the same time (VSTi's, reverbs), this might happen.
#5 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 25 April 2013 - 04:35 PM
+1  I've seen this happen with other recording programs as well, and not just when using Line 6 plug-ins.  Sometimes it's due to buffers being too small.  Have you tried increasing the buffer size in Reaper or in the ASIO driver?  I would not change them both at once.  See if either of them fixes the problem independently.
#6 JimboTN
JimboTN
  • 3 posts
Posted 21 June 2013 - 01:13 PM
Suggestions seem reasonable...any success?
