M13 firmware update issues
m13 firmware flash update
10 replies to this topic
#1 bcolexxx
bcolexxx
  • 1 posts
Posted 15 July 2014 - 05:10 AM
Hello people! I'm brand new to the Line 6 forums.
I'm having a few issues updating the Firmware on my LINE 6 M13.
The pedal is awesome (when it works).
So everything stopped working and i stopped getting sound out of it. When I hook up my cables, you can hear this buzzing when you turn the overdrive effects on, so there definately is a connection there, but when you plug the guitar in nothing comes through. I have of course tested out all cables and everything.
So I did some digging and I am on something like 1.07 firmware, and I need to upgrade to the newest one.
I've been following the instructions that I found here (http://line6.com/sup...structions-r364)
They are easy to follow but still nothing. I've tried it using MIDI-OX utility. I download the Sysex file, and follow it step by step. When I'm in MIDI OX and I send the file through to the unit, my little USB Midi device lights up (it has LEDS for Midi in and Midi out, and the Midi Out is flashing indicating that it's sending midi data through the out cable).
My poor old M13 just sits there, on the display it says 'Waiting command'
I get all the way to the end sending the Sysex data over, but it looks like the M13 is not recieving it.
Just wondering if anyone has had any experience with this and if anyone has successfully done it!
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9243 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 15 July 2014 - 05:23 AM
What MIDI interface are you using? This is probably the biggest thing. It really needs to be one that isn't using the default Windows drivers. The ones that Line 6 recommends in that document are what you should be using. If you have one of those, that's a major obstacle out of the way.
Secondly, I'd try using this program instead of the MIDI OX program. http://www.bome.com/products/sendsx
Personally, I never got the MIDI OX program to work.
One last thing is that you only really need one MIDI cable to do the update. You just need the cable going from the MIDI out of the adapter to the MIDI in of the M13. You don't need two-way communication to do the update.
If you follow those steps, you should have a pretty high probability of success.
#3 psarkissian
psarkissian
    Line 6 Staff
  • Service Engineer Moderator
  • 1954 posts
  • LocationCalabasas, CA
Posted 15 July 2014 - 07:57 AM
Version 2.04 is the current one.
#4 tommybluenote
tommybluenote
  • 1 posts
  • Registered Products:1
Posted 06 September 2014 - 10:41 PM
phil_m, Thanks for the tip about sendsx. When attempting to upgrade to 2.0 using Midi-OX, the process failed with a 'format error'. And left my m13 unit in a bricked state. Cycling power returned to the waiting for upload message, but each time I tried to to this with Midi-OX same error. I installed sendsx, set the midi out accordingly, and as a result, I've upgraded to 2.04.
#5 gperc
gperc
  • 2 posts
Posted 27 March 2017 - 10:14 AM
Hi I'm new and am trying to find 2.0 upgrade for m13 can anyone please send a link?
#6 psarkissian
psarkissian
    Line 6 Staff
  • 1954 posts
Posted 27 March 2017 - 12:27 PM
2.00 is no more, unless there's a link to legacy version, 2.01 is as far back as it goes.
2.04 is the current version.
http://line6.com/software/index.html
#7 doctorspooky
doctorspooky
  • 3 posts
Posted 09 May 2017 - 08:49 AM
I tried it your way; I get the format error message right away. What am I doing wrong?
#8 psarkissian
psarkissian
    Line 6 Staff
  • 1954 posts
Posted 09 May 2017 - 11:03 AM
Did you download the drivers for the brand of MIDI interface that you are using?
For instance, if using an M-Audio interface, then the compatible drivers for that version
interface, for the computer OS, has to be used.
#9 doctorspooky
doctorspooky
  • 3 posts
Posted 10 May 2017 - 07:18 AM
Yes; I reopened midi ox, changed something, and it worked. However, I did the same thing on my second m13, without changing anything, (except plugging in the midi cable into it) but download fails every time. I re-installed midi ox to get its defaults back, but the user settings obviously doesn't Uninstall
with it. Now, I am looking for that so I can delete it, and start over again (changing permissions and ownership along the way, so I have full access to the files I put on there).
#10 psarkissian
psarkissian
    Line 6 Staff
  • 1954 posts
Posted 10 May 2017 - 07:48 AM
Procedure for a global reset to factory default settings,...
http://line6.com/sup...rt/manuals/m13
... on page- 2.4 in the Advanced Manual.
#11 doctorspooky
doctorspooky
  • 3 posts
Posted 16 May 2017 - 12:16 PM
What am I doing wrong? Delay between buffers is 101, and the delay after f7 (which is ticked) is set to 68 ms. The MIDI IO setting is right, which uses my MAUDIO Delta Adiophile. My first M13 set up correctly using these settings, but the second one won't. It'll download packets, but after a while it fails. Please help. Thanks!
Also tagged with one or more of these keywords: m13, firmware, flash, update
