Expression pedal goes to a maximum of 50-60%
pod x3 live
2 replies to this topic
#1 klejdi12
klejdi12
  • 1 posts
Posted 19 July 2014 - 10:10 AM
Hello! I'm having this problem with my pod x3 live, when I use the built in expression pedal in the toe position it goes up to 50-60% of the value. If i have it set to a volume pedal, when i switch to wah by pressing the toe the volume goes from 50% to full, so it practicaly doubles the volume, making it unsuitable for use. If anyone knows a way to fix it, would be appreciated.
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15699 posts
  • LocationOntario, Canada
  • Registered Products:15
Posted 19 July 2014 - 10:26 AM
First, try recalibrating the pedal:
Q: How do I calibrate the Expression pedal on the POD X3 Live?
A: 1. Go to test mode by holding down 'Right' on the directional pad when you power up.
2. Highlight Pedal Cal.
3. Press the INPUTS button.
4. Set the pedal to the heel position.
5. Press the A footswitch to get data on pwm duty cycles.
6. Set the pedal to the toe position.
7. Press the B footswitch to get data on pwm duty cycles.
8. Press the C footswitch for automatic selection of the best duty cycle.
9. Move the pedal to get smooth 0-255 Scaled Values.
10. Press the D footswitch to save the settings.
  • 1
.... John Lennon
#3 felres21
felres21
  • 1 posts
Posted 10 April 2015 - 09:13 AM
Hi im having the same problem i did the calibration procedure but when ihave to put the scale value after you push tne C button it goes crazy and not staiying still, what can i do??
Also tagged with one or more of these keywords: pod x3 live
