Can't record decently with UX1
recording ux1 pod farm 2.5 windows vista cubase reaper
Best Answer BillBee , 23 July 2014 - 10:43 AM
This does blow - I did a search and whew there have been some interesting threads about "pops, crackles, spikes. etc." - iirc there were ideas such as "turning indexing off" , "graphic card interference" "amd processor support" and more. Never really came across a certain "fix"
As it was working fine, the big question would be "what changed?" (the UX1 or your PC).
I would try the UX1 on a different pc just to narrow the field down a bit - if it checks out good - head back to the laptop and check the input and output settings (DAW, Farm, Windows internal volume settings for out) PF is working its just the signal into the DAW.
After that I venture into the land of guesswork :(
-Run a virus trojan/adware scan - can't hurt anyway.
-Try the laptop in a different room on battery only - who knows
- The unistall/reinstall shuffle.
Wish I could be more help.
B
Go to the full post
9 replies to this topic
#1 cruz616
cruz616
  • 5 posts
Posted 22 July 2014 - 05:43 PM
Hi! I'm hoping you guys can help me. I bought a UX1 about 7 months ago, I jammed with the POD Farm 2.5 with no major problems, also I've downloaded Cubase 5 in order to record stuff. I've recorded some short tracks with it, and it was pretty good.
About a week ago I tried to record something with the POD Farm (in the standalone mode) and the Cubase.....when I listened to what I've recorded , my ears bleed! :wacko: . It sounded horribly distorted with lots of fuzz, latency and noises.
I double checked my POD Farm and everything sounded cool as always, so I thought it could be the Cubase...I run POD Farm as a plugin in Cubase and it was the same horrible, distorted, noisy problem.
Then I thought it could be a matter of Cubase, so I downloaded Reaper and set the UX1 to work with it and....it was the same! :angry:  Once again the POD Farm sounded awesome by itself but when I listened to what I've recorded with Reaper, it was the same story: distorted and crackled!
I've done everything : change the buffer in Reaper, use better and shorter cables, updated the POD Farm with the Monkey, optimize my Vista laptop.....PLEASE HELP ME!
POD Farm is working just fine...but I can't record anything without sounding like crap. I'm desperate :(
#2 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2572 posts
  • LocationNew England
  • Registered Products:3
Posted 23 July 2014 - 04:04 AM
I've heard of others with this problem, but never seen anything resolved.  To me it sounds like there is a preset on in PodFarm doing this, or that the recorded signal is getting passed through PodFarm twice (distortion X distortion is never good) - ie recorded signal is 'wet', then it is put through the plug-in on playback.
Have you tried recording a 'dry' guitar signal, then adding PodFarm (plug-in) after recording?
#3 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 23 July 2014 - 04:14 AM
Consider the POD Farm Plug-In as a post processing effect.  It should not be used during recording, but use it on playback.  As fflbrgst mentioned, try recording the guitar signal dry, and then adding the PF 2.5 plug-in afterwards.
Try this; record with PF 2.5 stand-alone open.  In Cubase or Reaper, are two stereo tracks.  Use one of the tracks for sends 1 & 2, Use the other track for sends 3 & 4.  Sends 3 & 4 will be dry.  After recording, add the PF 2.5 plug-in to the track that has sends 3 & 4.  The track with sends 1 & 2 will be your reference track, and can be later used or deleted as you see fit.
#4 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
  • Registered Products:8
Posted 23 July 2014 - 04:19 AM
I hit this in Reaper with a UX2 (super distorted in a bad way) turned out I had the UX2 output screamingly high. Make sure that UX1 knob is not "full tilt" ~ between 4 - 6 is fine.
I hope its just a setting issue in the DAW or UX1.
Smell the glove.
#5 cruz616
cruz616
  • 5 posts
Posted 23 July 2014 - 08:35 AM
thanks guys! , yeah my ux1 knob it's fine not in super output mode, so that couldn't be it....
I've just tried what BigChas52 said, but it's still sound the same....
I'm in a hurry to record something, so should I reformat my laptop and reinstall everything again to see if that fixes it? Or maybe is that the Ux1 got corrupted by a virus or something like that? :(
#6 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
Posted 23 July 2014 - 10:43 AM   Best Answer
B
  • 1
Smell the glove.
#7 cruz616
cruz616
  • 5 posts
Posted 23 July 2014 - 12:13 PM
Thanks a lot for your help,BillBee. I'll try to do everything that you suggested.  Hope it works.
Now, kinda newbie question, but trying (and obviously installing) the UX1 in another PC won't affect my licences or something alike? I remember something about I can't run the ux1 in more than one PC...but I maybe wrong.
Well, I'll try to see if it works. If don't I guess I'm pretty screwed
#8 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
Posted 23 July 2014 - 02:08 PM
You can run your UX-1 on as many computers as you like. BTW, if you click on the "Help" section of POD Farm, you'll find the manual.  There are some good tips for setup and recording in there ;)
  • 1
#9 cruz616
cruz616
  • 5 posts
Posted 23 July 2014 - 03:43 PM
Thanks, BigChas52! I'm installing the UX1 in my dad's PC to see if it's indeed a matter of my PC.
I will also check the POD Farm manual as you suggest :)
#10 cruz616
cruz616
  • 5 posts
Posted 23 July 2014 - 05:13 PM
It worked guys! I installed the ux1 in my dad's desktop PC and the POD Farm even sounds better by itself!
it still doesn't record QUITE as accurate or with the fidelity that I'd like to... it's kinda quiet compared to what I've just played, but it's 10000x times better than when it was on my lap!
Any tips for that? Maybe it's the buffering in Reaper? :) Please let me know. Thanks again for all your help!
Also tagged with one or more of these keywords: recording, ux1, pod farm 2.5, windows vista, cubase, reaper
