RichG Posted July 25, 2014 Share Posted July 25, 2014 I run a number of XD-V70/V75 units into one pair of antennas. I plan on mounting a wireless router (ASUS RT-N66U) into an X32 rack mixer for wireless mix control. Does anyone know of any interference issues with running XD-V70's in a rack along side a wireless router? Should I run the router at 5 GHz? Quote Link to comment Share on other sites More sharing options...
dboomer Posted July 26, 2014 Share Posted July 26, 2014 Your best bet to avoid interference on either side is to set your router to run 5g ONLY. Be certain to switch off the 2.4g It's never a best practice to set a transmitter close to an unintentional receiver. If you were to run paddle antennas you could easily get some distance between the two. Quote Link to comment Share on other sites More sharing options...
eklynx Posted July 29, 2014 Share Posted July 29, 2014 Here's a related off the wall question. Because antennas/frequencies are pretty much the same, can you chain the V75 antennas into an access point's antenna ports and just run one pair of rabbit ears? Or does the daisy chaining through the V75 do some sort of filtering that would prevent the AP from getting the full signal? Quote Link to comment Share on other sites More sharing options...
dboomer Posted July 29, 2014 Share Posted July 29, 2014 Well I guess you could, but you would likely wipe out the V75 receivers. The AP would be shoving full power into the wireless mic receivers. It directly contradicts my "best practice" note above. ;) Quote Link to comment Share on other sites More sharing options...
