Controlling A Strymon Timeline By Midi From The Hd500
timeline hd500 midi
6 replies to this topic
#1 starkjo
starkjo
  • 2 posts
Posted 08 June 2013 - 11:18 AM
I use the HD500 as the backbone of my rig, and have some pedals in the HD500's fx loop. The HD500 also sends out MIDI program change messages to a Strymon Timeline, so the Timeline's preset changes to the currently loaded HD500 preset. My question is as follows. When I select a preset on the HD500, can I also program the HD500 to send out some form of MIDI message that changes the preset on the Timeline just as it does now, but that it ALSO puts the Timeline preset in 'off' state, ie. Timeline's preset loaded but not engaged. If it can be done, how? It doesn't matter how I save the preset on the Timeline itself, I already tried that - no matter if I save it in off or on state, it always turns on when the preset loads via the MIDI program change message from the HD500.
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 08 June 2013 - 11:20 AM
why not just turn the fxloop off? then it is basically engaged but not used.
#3 starkjo
starkjo
  • 2 posts
Posted 08 June 2013 - 09:55 PM
There are a few other pedals before the Timeline that are needed, so the HD500 fx loop must be on. The only solution I can think of is that the HD500 would send some sort of MIDI command to the Timeline in conjunction with the program change message from the HD500 to the Timeline (for preset change).
#4 tochiro
tochiro
    Iknowathingortwo
  • PipPip
  • 316 posts
  • Registered Products:3
Posted 08 June 2013 - 11:33 PM
But why change the preset on the Timeline AND switch it off?  You probably only need to switch it off on the current preset and change that preset later.  There is a specific midi number to bypass the TL (CC# 102 byp=0 eng=127) and that should do it.
#5 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 09 June 2013 - 04:42 AM
i've used an m5 similarly with the HD500... and it was as simple as hooking it all up via midi and making the changes (turn it on/off select preset) and hitting save on the hd500.
try doing that and save 2 identical tones right next to each other, for example 1A effects on, 1B effects off. no guarantee, because i don't have your exact equipment... but it worked flawlessly with the m5.
#6 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 09 June 2013 - 05:42 AM
....... When I select a preset on the HD500, can I also program the HD500 to send out some form of MIDI message ....
The HD500 can send MIDI messages as described in Appendix B of the Advanced Guide. The MIDI messages sent when you switch presets are pre-defined. However, you can assign controllers (FS1-8, etc...) to send additional MIDI messages within a preset.
.... John Lennon
#7 ReverendLove
ReverendLove
    Iknowathingortwo
  • PipPip
  • 124 posts
  • LocationCologne, Germany
  • Registered Products:4
Posted 08 August 2013 - 06:51 AM
Hi starkjo,
loosing the last state of a preset is a bug of the timeline, which is fixed now.
Try the new beta firmware (1.43) for the timeline. If you switch to a other program the timeline will remember the last bypass/on state.
Also tagged with one or more of these keywords: timeline, hd500, midi
