Control Lag On Gearbox
podxt lag latency gearbox
No replies to this topic
#1 formaldehyde
formaldehyde
  • 1 posts
  • Registered Products:1
Posted 08 June 2013 - 05:50 PM
I have a podxt that I have hooked up to my studio computer and I've been using gearbox for so long that the controls on the unit are a little dusty and do strange things, so I tend to just leave the pod alone and use gearbox to control it. However my studio computer recently went down, so obviously when setting up the new one I got the latest version of the pod drivers and gearbox. Now I'm experiencing latency when I try to adjust any of the parameters.Turning controls on and off is fine, it all seems fairly sharp and responsive, and the audio latency is very low so there doesn't seem to be any problems with the USB connection. However when I try to adjust say, modulation frequency, delay times, volume, tone, gain, anything like that, instead of following my mouse based controls (entering raw data values also works instantaneously) the values ramp up to the new values. So if I use my mouse to change my modulation frequency from 0.1Hz to 15Hz, it takes a couple of seconds to get to that frequency. Even worse, if I quickly raise the values to max and back again, it will take a few seconds to ramp up to the top value and back again. The same happens when I adjust the delay times. The ramping on volume and gain is a lot quicker but it's still the same phenomenon and it's driving me insane. Is there a setting I should be turning off.
Cheers
- James
