Loud pop when turning on amp?
9 replies to this topic
#1 SpiderJam
SpiderJam
  • 5 posts
  • Registered Products:2
Posted 28 July 2014 - 09:39 PM
I've had my AMPLIFi 75 for a couple of days now.  Over all I like it, but every time I flip the power switch to turn it on I get a loud pop from the speaker.  Does anyone else have this issue?  If this is not the norm, I'm going to go through the hassle of swapping it for another one.
Thanks.
#2 thiago_gp
thiago_gp
  • 1 posts
  • Registered Products:1
Posted 29 July 2014 - 07:50 AM
I'm no audio/eletric technician but I know a bit about amplifiers, maybe you'll give a penny for what I think it is:
If the amplifier makes the loud pop even when no cable is connected, you bet it's the amplifier. I would return it, if your warranty expired I would send it to a technician for evaluation, maybe it's no big deal. Sometimes the switch has some poor contact, he'll swap to another one and problem solved.
Inadequate voltage or voltage oscilations in the energy coming out of your wall outlet might be causing this too. Try using a surge protector or try plugging it to a UPS no break, the surge protector regulates the voltage an eletric device receives by blocking or grouding the voltage so that it is safe for the equipment. Same goes for the UPS, but it will condition and equalize the voltage more precisely. The pop you hear might be some extra voltage, this might damage the device pretty bad.
#3 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 29 July 2014 - 08:10 AM
Some amps do this and some are designed not to do this.  We need other owners to pipe up here.
#4 archtopeddy
archtopeddy
    Iknowathingortwo
  • PipPip
  • 156 posts
Posted 29 July 2014 - 10:52 AM
I have the 150. I do not get a pop -- loud or otherwise -- when I turn on my amp.
#5 SpiderJam
SpiderJam
  • 5 posts
Posted 29 July 2014 - 05:46 PM
The amp pops the speaker at turn on when it's been off for a short time, with or without a guitar cable connected.  I've also tried it powered through a Furman power supply and it still pops.  Looks like I will be swapping it out.   :(
#6 vlxjim
vlxjim
  • 30 posts
  • Registered Products:3
Posted 30 July 2014 - 10:53 AM
I have the 150 and there is no pop. Just the lightest noise not a pop more like a low huff.
#7 Old_School_LP
Old_School_LP
  • 3 posts
Posted 04 August 2014 - 07:21 AM
My AMPLiFi 75 does it too. I originally bought the floor model. It did it too.
I just exchanged it for a brand new one in the box. Same thing..
No big deal I guess..
I'm also getting a LOT of noise and Humm on medium to high gain settings even with the noise gate on..
Anyone else??
#8 michaeltyyz
michaeltyyz
  • 1 posts
Posted 05 August 2014 - 10:21 AM
I haven't had problems with gain - just the popping sound.
#9 SpiderJam
SpiderJam
  • 5 posts
Posted 05 August 2014 - 06:20 PM
Got the replacement amp.  Same exact popping sound at turn on.  Looks like I'm just going to have to live with it.  :(
#10 jhschmitt
jhschmitt
  • 48 posts
  • Registered Products:5
Posted 22 August 2014 - 05:43 PM
I get the same popping sound when turning on my Amplifi 75 or Spider IV 150.
I thought it was just a quirk of Line 6 amps.
It is a little annoying.
Did it once with the headphones on and that hurt a bit.
