clean up pod hd 500x
michel101
Search the forum. I'm sure someone some time ago posted an 'empty' setlist. You could then use the editor to load the empty setlist into your device, one setlist at a time.
Of course you can create your own 'empty' preset/setlist (probably in less time) by manually removing all the amp/fx from a preset. Then copy that empty preset into all preset slots in the setlist. Then save the setlist using the editor, and reload it into all other setlists.
If you want to restore the factory presets (and you didn't originally save the setlists) you will have to reinstall the firmware and choose not to keep existing presets.
personally I find the best way to do this is to reflash the latest firmware electing not to keep any current tones.  I then do a fresh global reset and pedal calibration.  Set my output and pedal configuration and set inputs to preset not global.  Now I have a fresh POD to work with.  Save one of your new empty setlists to the computer and you are good to go.
