Accessing the boost function of the DT amp via PodHd500x?
2 replies to this topic
#1 coosvandorsten
coosvandorsten
  • 3 posts
  • Registered Products:3
Posted 03 August 2014 - 02:59 AM
Is this possible via 6Link? The boost function is set to on in a lot of HD pre amps by default. It would be nice to have this function accesible via one of the ia swichtes of the hd500x.
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17705 posts
  • LocationClemmons, NC USA
  • Registered Products:16
Posted 03 August 2014 - 05:15 AM
the "boost" function is an internal amp parameter in the DT50, that boosts the signal from the preamp to the poweramp...
has nothing to do with a typical boost that you would engage or disengage while performing....
not saying it can't be done... but it's not what you think, won't give you the results you want, and shouldn't be done....
the only exception is if you're trying to build a standalone DT amp using the various parts and pieces with the DT 2.0 software....
besides... everytime you select an amp in the pod the boost will revert to it's authentically modeled correct state for that setup.
seriously... if you want a "boost" while performing... look elsewhere.
(you only have like 1000 other options built into the pod)
  • 1
#3 wowza
wowza
  • 34 posts
  • Registered Products:2
Posted 15 August 2014 - 04:35 PM
I have done it and as TheRealZap said it really didn't do as much as you think. I experimented with it after they released it with the update just got kicks. Haven't bothered with it since.
