Weird Noise Using Ux1. Please Help.
13 replies to this topic
#1 Robert1969
Robert1969
  • 41 posts
  • Registered Products:1
Posted 09 June 2013 - 03:23 PM
I don't know if this is a PC related issue or one with my UX1, but I'm getting this very odd kind of crackling hiss/white noise when I'm using the UX1. Here's an audio clip of the problem,
To help rule out various other factors, I tried using the UX1 with both Reaper and Riffworks and get this same kind of white noise/crackling hiss as the note/chord fades. I tried using different guitars, different guitar/usb cables, real/sim pedals, and every amp sim I've got archived. I've also tried standing well away from my PC while recording, as well as taking the PC to 3 other rooms in my house, but to no avail. Keep getting this noise no matter what and where I do it. That said, I like to rule out the UX1 as the culprit before I take my PC in to the shop to get it looked at.
Also, if it's of any help, I'm running Win 7 64 bit, and my drivers, both PC and Line 6, are up to date.
Any input would be extremely welcomed at this point.
Thanks.
#2 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7362 posts
  • Registered Products:6
Posted 10 June 2013 - 07:11 AM
I can't currently dl the clip, but crackling/white noise is usually the USB bitstream being interrupted.
Check out this doc:
http://line6.com/sup...roubleshooting/
#3 Robert1969
Robert1969
  • 41 posts
Posted 10 June 2013 - 09:12 AM
Check out this doc:
If you listen to the clip I posted, you'll hear that it's not exactly a burst of white noise, but some kind of sonic artifact that kicks in as the note/chord fades. This sound is present on clean DIs as well, but is really exacerbated by levels of added gain.
#4 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7362 posts
Posted 10 June 2013 - 11:02 AM
I'll check it out later tonite when I can access the clip.
#5 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7362 posts
Posted 10 June 2013 - 02:20 PM
I think aliens  are sending you a message!!  :o
Do you hear this in headphone connected directly to the UX1 too?
Do you hear the some thing if you have an entirely blank path in POD Farm?
#6 Robert1969
Robert1969
  • 41 posts
Posted 10 June 2013 - 03:02 PM
I'm monitoring with headphones, so yes, I'm hearing it through them.
I'm getting this same sound now matter what sim or DAW I use. I'm hearing it on totally clean signals as well, only not nearly as pronounced. The severity of the noise/sound, it seems, increases in proportion to the amount of gain I'm using as well.
Like I said, I tried using two different guitars, different guitar/usb cables, different usb ports, and different wall sockets. I also tried standing far away from my PC to record/monitor and still got that sound. I got it using POD, Amplitube, and every other amp sim I own. I've updated all my drivers as well.
Am thinking my next step might be to wipe my PC and try a reinstall of Win 7.
#7 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 10 June 2013 - 03:32 PM
It might be simpler to try using another computer as a test first. Maybe borrow a laptop for a couple of hours?
.... John Lennon
#8 Robert1969
Robert1969
  • 41 posts
Posted 10 June 2013 - 03:56 PM
I do need a laptop. Maybe this might be a good time to go looking around for one.
#9 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7362 posts
Posted 10 June 2013 - 05:42 PM
Sounds like you tried a lot to try and isolate the problem.
I understand you hear it on a clean patch, but just to clarify, have you tried an empty patch?
If you engage the tuner do you hear the same?
+1 to Silverhead, is there a friend's computer you can try it on in another location?
The sound reminds me of some funky noise gate settings.
Like you have a gate teetering on the threshold followed by some modulation effect.
#10 Robert1969
Robert1969
  • 41 posts
Posted 10 June 2013 - 06:51 PM
+1 to Silverhead, is there a friends computer you can try it on in another location?
If I create a new project in Reaper or Riffworks, and play through it clean, I can still hear it, although it's much fainter sounding without any sims on it.
No noise gate or other types of modulation on that clip. Signal chain was guitar> UX1> tube screamer sim> LeCto> KeFIR
DAWs don't matter though. Keep getting that sound no matter what equipment I use.
#11 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7362 posts
Posted 11 June 2013 - 04:00 AM
OK, you got more things going on here than I originally thought and it is probably confounding the process of elimination.
This is what you need to try.
Guitar>>UX1>>Reaper
For the UX if you are using POD Farm (standalone) have a signal path with nothing, no amps, no stomps, no reverbs, ect...
In Reaper create new project and a new track and make sure there are no plug-ins whatsoever.
Also in Reaper make sure you are selecting Line6 ASIO UX1 as your device in preferences.
#12 Robert1969
Robert1969
  • 41 posts
Posted 11 June 2013 - 04:41 AM
Guitar>>UX1>>Reaper
I've tried all this stuff before, and I still get this phasey/crackling noise. Doesn't matter what DAW or kinds of sims I using, I still get this noise. Got I with POD Farm, got it with Amplitube, and get it with every other amp sim I use.
Got Reaper recognizing the UX!'s drivers, same too on Riffworks.
I've tried regulating buffer sizes, updating drivers, changing gear, changing rooms, running my machine unconnected to the web, with no background programs running, and I'm still getting this phasey/crackling sound.
#13 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7362 posts
Posted 11 June 2013 - 04:48 AM
Do you have a 1/4" to 1/8" adapter?
If so, try plugging your guitar directly into your PC's soundcard via Line or Mic in.
#14 Robert1969
Robert1969
  • 41 posts
Posted 11 June 2013 - 08:06 AM
So after reinstalling POD Farm that weird phasey sounding artifact ceased. Only thing is I have to keep POD Farm open, whether I'm using it or not, to keep that sound that from going back.
Oh well, seems a small price to pay for the convenience I'm getting.
