Roland190877 Posted August 9, 2014 Share Posted August 9, 2014 I have a serious problem setting up my signal chain. I'm using a HD500 connected to a DT50 Head via Line6 Link. The signal chain is Guitar in - Noisgate - Wah -Amp Pre Model (-Delay -Reverb) -DT50 For some strange reason the effects post the amp simulation won't work. They show up correctly in the HD500 edit software are turned on etc. but have no effect. Putting them before the amp works.... but sounds terrible. Seems to me like I miss some little detail that i just can't see.... HELP ! Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 10, 2014 Share Posted August 10, 2014 You have a choice of where the DT50 receives audio from the HD500's signal chain. In HD500 Edit, you can set this parameter under the "Mixer" tab. You'll see under the L6 Link section there that you have Amp 1, Amp 2, Amp 3 & Amp 4 listed, and for each one there's two pull down menus - "Audio" and "Control". Assuming you only have one DT50, you just need to set the Amp 1 one. If you want the DT50 to amplify effects after the amp model in the HD500's signal chain, you need to make sure you select the "Left/Right" option here. This setting can also be changed without being connected to HD500 Edit. It's on page 9 of the setup menu. 1 Quote Link to comment Share on other sites More sharing options...
Roland190877 Posted August 13, 2014 Author Share Posted August 13, 2014 Thank you very much for the reply. Problem solved. Sometimes it's so easy when you know where to click ;-) Quote Link to comment Share on other sites More sharing options...
