hd500 in stereo with 2 combos?
hd500 stereo effects loop
5 replies to this topic
#1 vinnies
vinnies
  • 5 posts
Posted 10 August 2014 - 04:34 PM
i'm running my hd500 into my boogie dc5 combo. i'd like to use the dc5's tone and use the stereo effects of the hd500 in stereo. right now, i primarily run the hd500 effects only, no modeling - i'm in love with the boogie tone and haven't found an equal in the models. how do i set up the loop from the hd500 to 2 amps? do i run the single hd500 send into a TRS with 2 1/4" cables out of the single TRS to the 2 amp's loops? thanks...
#2 GTLazer
GTLazer
    Iknowathingortwo
  • PipPip
  • 215 posts
  • Registered Products:1
Posted 12 August 2014 - 01:29 AM
You'll need a Y cable (TRS to 2 x TS), as the HD500's loop out is a stereo TRS but you'll need mono TS inputs for your amps.
Careful with the effects you use as well, as some of them will sum to mono.
You like my answer? Hit the up arrow. You no like my answer? Hit the down arrow. Sorted.
#3 vinnies
vinnies
  • 5 posts
Posted 13 August 2014 - 03:33 PM
awesome, thanks. that makes sense...
#4 alexisltd
alexisltd
  • 53 posts
Posted 14 August 2014 - 02:43 AM
Another option is: guitar - pod HD500 input - pod HD500 send - Dc5 input - Dc5 send - pod HD500 return - pod HD500 L/mono output - Dc5 return....then pod HD500 R output to 2nd amp`s return
  • 1
#5 vinnies
vinnies
  • 5 posts
Posted 15 August 2014 - 05:44 PM
thanks alexis, that worked out great for the stock hd500 stuff, got stereo! i don't have a loop on my second combo, but went into the front of it. like the 4 cable method, i lose the boogie tones using this tho.
#6 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 26 August 2014 - 02:42 AM
'.... how do i set up the loop from the hd500 to 2 amps? do i run the single hd500 send into a TRS with 2 1/4" cables out of the single TRS to the 2 amp's loops?....
check out this post.
contains the "stereo 4cm" cable connections...
Also tagged with one or more of these keywords: hd500, stereo, effects loop
