aquaplane22 Posted August 11, 2014 Share Posted August 11, 2014 Hey Friends, I have searched for an answer could not find one I apologize if this has been covered. I have been recording direct USB with POD HD PRO with no trouble I usually use a rack tuner.. then I used the inbult tuner for the first time since exiting the tuner I am getting the reported clicks and pops when using it as a soundcard in my DAW. Sample rates are matched between DAW and POD CPU usage or buffer size is not causing it only running at 3% I used Monkey which detected my POD fine went to update flash memory which is the reccomended fix, while installing it says timed out waiting for a response from the unit please make sure cables are plugged correctly. I have changed USB ports and tried again, restarted my computer and Monkey still the same problem. All cables are fine and working and Monkey has no problem seeing the device it just wont respond during the install process. Also pod HD edit is not seeing device and is saying to update firmware since I exited the tuner.. very frustrating mid session! Any help to get around this would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
andreyrodriguez Posted August 21, 2014 Share Posted August 21, 2014 +1 I have the same problem with HD500 in OSX 10.9.3 Monkey not detected device. Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 21, 2014 Share Posted August 21, 2014 Try downloading the Flash Mem file outside of Monkey. Then in Monkey update flash from file (instead of having Monkey do it auto aromatically). @andreyrodrguez, I think you have a different issue, make sure you have the newest version of Monkey, if that doesn't work I would start a new thread and/or contact Line6 via phone or support ticket. Quote Link to comment Share on other sites More sharing options...
