Spider iv 75...Dont undestand volumes??
ChuchoMaGu
Hi!
I recently get a Spider iv of 75 watts. I was so excited about it, but then i start with trouble.
I was playing...testing the presets and making mine but suddenly I realized that the volume was too high in some of them, I didnt want to change the master volumen every time I change my channel...so I start reading the manual and I start changing my channel volume....I was doing fine, until I try to change the channel volumen of one of my presets.
An example
    Drive          Bass          Mid          Treb          Channel Vol.
       7                6               4               8                     3                 (On the display and knobs)
This is how i safe my preset
Then I move chanel volumen becouse it was a little bit down so it end like this...
       7                6               4               8                     5                 (On the display and knobs)
BUT!!! the volumen just went all the way down.... so I needed to turn the channel volume all the way up just to get a lower sound than the initial one.
What am I doing wrong?
  • 1 year later...
set the master at a comfortable level... try the tones... raise or lower the channel volume (THEN SAVE)
after doing this the master volume will raise and lower all the patches reasonably...
So do I understand this to mean.........I can start out with "any" preset,  make adjustments to it ( vary knob settings ) then do a SAVE.  and that preset is now altered to be that way in the future?
i may be misunderstanding the question...
but yes if you hit save after adjusting it will recall the tone as it was saved...
the master volume will not be recalled..... that should be the only adjustment you need to make and you're patches should be "relatively" leveled before hand....
