Is it possible to control 2 sv hd100s with 1 fbv express mkii?
10 replies to this topic
#1 Hollatchaboy72
Hollatchaboy72
  • 22 posts
  • Registered Products:3
Posted 17 August 2014 - 06:33 AM
Im looking to run 2 sv hd100s via x3pro thru the effects loop in stereo. what iwant to know is, can i control the amp modelers on the amps, with 1 fbv express mkii?
#2 Hollatchaboy72
Hollatchaboy72
  • 22 posts
Posted 17 August 2014 - 02:46 PM
Better yet, just the banks and channels.
#3 radatats
radatats
    Power User
  • PipPipPipPip
  • 2322 posts
  • LocationOrange County, NY
Posted 17 August 2014 - 03:24 PM
Not sure I understand... sounds like you are running a POD X3Pro into the FX return of 2 SV100's right?  If so then you are bypassing everything in the SV100 and just using the tube power amps for the X3Pro which would be controlled by the FBV...  That's how I would run it...
#4 Hollatchaboy72
Hollatchaboy72
  • 22 posts
Posted 17 August 2014 - 03:42 PM
Right, except, from what I've been lead to believe, it still uses the app modelers on the spider valve. So I want to be able to control banks and channels on both amps from 1 footboard.
#5 radatats
radatats
    Power User
  • PipPipPipPip
  • 2322 posts
Posted 17 August 2014 - 06:20 PM
Wrong.  You use the amp modelers in the X3Pro.  everything is done inside the X3Pro.  The SV100's are just power amps.  From the manual, as soon as you plug into the FX return, the preamp section is disconnected.
#6 Hollatchaboy72
Hollatchaboy72
  • 22 posts
Posted 18 August 2014 - 02:37 PM
I thought it said only the effects go thru the effects loop, not the amp modelers.
#7 Hollatchaboy72
Hollatchaboy72
  • 22 posts
Posted 18 August 2014 - 02:40 PM
By the way I'm using the 4cm. That way I believe it still uses the modelers on the amp, and just the effects from the x3 pro.
#8 radatats
radatats
    Power User
  • PipPipPipPip
  • 2322 posts
Posted 18 August 2014 - 07:18 PM
Ok, now we are back to square one.  And I am pretty sure it is still no, you cant feed two devices with one pedal.  The models in the X3Pro are the same as the SV100 right? POD Farm 2?  You should try the X3Pro the way I described... I bet you like it and is's more usable...
#9 Hollatchaboy72
Hollatchaboy72
  • 22 posts
Posted 18 August 2014 - 07:20 PM
Will my effects run in stereo that way tho?
#10 radatats
radatats
    Power User
  • PipPipPipPip
  • 2322 posts
Posted 18 August 2014 - 07:39 PM
absolutely.  Depends entirely on how you set things up in the X3Pro.  Chapter 7 in the advanced guide details sending separate tones to two amps.  Or you just send one tone with stereo effects to two amps.  Give it a try...
#11 Hollatchaboy72
Hollatchaboy72
  • 22 posts
Posted 18 August 2014 - 07:59 PM
Alright cool man! I will!
