Pod HD500 Expression pedal/Parameter issue
riffboy
I'm having a weird issue with my HD500 and onboard expression pedal. I set my expression pedal to control the mid parameter on an overdrive within the menu, then exit out. When I go back in I see the expression is now controlling the drive level. Doesn't matter what I do the preset will not save the mid control by the expression pedal. Anyone have any idea what's going on, or experienced anything similar? Thanks.
Yeah I've done that. The problem isn't that the expression not controlling the parameters, it's just it's controlling the wrong parameter. I set it to control the mid parameter on the overdrive, but when I exit the screen and check it again the parameter to be controlled has changed from mid to drive. Not sure why, or how it's doing that.
