julius60 Posted August 19, 2014 Share Posted August 19, 2014 Hi, I change for OSX 10.9, and since it's not possible for me to connect my pod .... not detected .... And i have a message for OSX : too much consumption of energy with usb, usb disconnected (i tried too translate the french message...) I also have a problem with my pod usb plug , she's broken....so i'm not sure it's come from the pc or form the pod.... But what i saw is the last drivers cannot be install ... why ?? don't know.... i tried a lot of time... but it's seems there are a lot of person here have the problem... Any solution to solve it ?? and, is it possible to connect podhd with USB/midi cable to update firmware and use podhd edit ? Thanks a lot. -Ju- Quote Link to comment Share on other sites More sharing options...
andreyrodriguez Posted August 21, 2014 Share Posted August 21, 2014 +1 I have the same problem. Quote Link to comment Share on other sites More sharing options...
stumblinman Posted August 21, 2014 Share Posted August 21, 2014 Pods had a problem with a weak USB plug for a while. Repairing the USB on the pod would probably fix your problem. I could quote all the other troubleshooting options that you could find with a simple search, but I will simply state this instead: if your USB port is broken, get it repaired. There are YouTube videos to show exactly what to do. Google is your friend. Hi, I change for OSX 10.9, and since it's not possible for me to connect my pod .... not detected .... And i have a message for OSX : too much consumption of energy with usb, usb disconnected (i tried too translate the french message...) I also have a problem with my pod usb plug , she's broken....so i'm not sure it's come from the pc or form the pod.... But what i saw is the last drivers cannot be install ... why ?? don't know.... i tried a lot of time... but it's seems there are a lot of person here have the problem... Any solution to solve it ?? and, is it possible to connect podhd with USB/midi cable to update firmware and use podhd edit ? Thanks a lot. -Ju- Quote Link to comment Share on other sites More sharing options...
scottyo78 Posted August 21, 2014 Share Posted August 21, 2014 Another thing to try... Mac OS 10.9 (Mavericks) is riddled with issues that cause many problems with DAW's. Try updating to 10.10 (Yosemite) and see if that helps. Quote Link to comment Share on other sites More sharing options...
