Jtv59 - Breaking Strings Too Often
2 replies to this topic
#1 guitarmech111
guitarmech111
  • 54 posts
  • Registered Products:1
Posted 11 June 2013 - 05:22 AM
I am having a LOT of trouble breaking strings. They are always breaking at a very bad time. It is always the 3rd and 4th strings. All other strings have not had the issue. They break at the saddle. With the piezos there, how could I remedy this issue besides changing the strings more often?
Also, what would be the rcomended guage to use? I use 10's now and I am thinking of going to 9's.
#2 moondancer
moondancer
  • 99 posts
  • LocationGermany
  • Registered Products:2
Posted 11 June 2013 - 06:07 AM
you should inspect the groove with a magnifying glass, if there is any sharp-edged damage. You can try to remove this by a sandpaper, but carefully you can injure the nickel-plating. If your guitar is under warranty you better contact your service center.
A friend had the same issue with an Epiphone LP-style guitar, the groove was to narrow, so strings broke always there. He had to send his guitar to service, 'cause couldn't repair it.
Stay tuned brothers
Regards Edgar
#3 thorneven
thorneven
    Iknowathingortwo
  • PipPip
  • 323 posts
  • Location"Upstate" New York
  • Registered Products:9
Posted 11 June 2013 - 07:06 AM
If you're not comfortable doing it yourself, take the guitar to a TRUSTED guitar tech who can re-cut the notches in the string saddles.  You may have to raise the bridge slightly to compensate for the deeper grooves in the saddles after the re-cut.  But like moondancer said, it is likely sharp edges in the cuts on the saddles... or poor quality strings.  Or you're an animal when you bend ;) .
One last thought... I don't know if recutting the saddles is safe because I don't know if that will affect the piezo pickups in the saddles.  Make sure your guitar tech understands the Variax.
1969 Les Paul Custom / Spider V 120 (studio) & 240 (stage) / FBV 3.  FORMERLY: JTV-59 + Pod HD500X + Spider IV, Vetta 2 / Behringer FCB1010. HISTORY: Spider IV, Spider III, AX212, Marshall, Acoustic, and various preamp + amp rack componentry.
