HD500X Times Out While in Edit?
fail hd500x time out edit
Best Answer Technogrim , 21 August 2014 - 09:34 AM
I have determined that it was indeed the usb ports.
It seems certain ports cut out occasionally and some don't work at all.
But I managed to find one and was able to edit and add a bunch of pedals to an entire brand new preset and saved it with no issues.
I'm super relieved....I guess it's time for a new motherboard.
Thanks everyone!
Go to the full post
5 replies to this topic
#1 Technogrim
Technogrim
  • 6 posts
  • Registered Products:1
Posted 20 August 2014 - 12:02 PM
So I just bought this thing and I'm trying to create my own presets in the in the Edit application running in Windows 7.
It works great, but for only a minute or two, and then the unit stops syncing and is locked on whatever sound I was currently at.  After that nothing responds.  If I turn pedals on or off, change pedals, change amps, the sound stays the same and I no longer see "syncing" on the device screen.
If I try to Receive anything I get an error message: Operation timed out, Code 8000000000a
When I unplug and plug the device back in it works again for only a minute then the same thing.
This is unacceptable.
Any ideas?  Did I just waste a lot of money?  Device is updated.
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16057 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 20 August 2014 - 01:42 PM
Sounds like a USB communications issue. Try different USB ports on your computer and avoid using any USB hubs. Sometimes the front panel USB ports on a desktop PC contain an internal hub; try the back panel ports.
.... John Lennon
#3 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 20 August 2014 - 04:35 PM
It clearly should not do that.  Try a different USB cable too.  Something is hosing up your USB connection.
#4 Technogrim
Technogrim
  • 6 posts
Posted 20 August 2014 - 04:57 PM
I'll try it tomorrow when I'm off work. The cable is brand new, which came with the device. I have it plugged into the back ports. If it was a cable issue why would it work for a bit then stop? I'll try different ports buy it doesn't make sense.
I'll let you guys know tomorrow.
#5 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2329 posts
  • LocationU.S.A.
  • Registered Products:17
Posted 20 August 2014 - 07:42 PM
I run the 500 edit program in administrative mode, right click on the icon and choose "run as administrator", you can also change the advanced properties of the program so it runs it like when you open it. Make sure your HD500 is the default sound card for Listening and Recording. Hope it helps with your problem.
#6 Technogrim
Technogrim
  • 6 posts
Posted 21 August 2014 - 09:34 AM   Best Answer
Thanks everyone!
  • 1
Also tagged with one or more of these keywords: fail, hd500x, time, out, edit
