Red Comp
8 replies to this topic
#1 bcbeast
bcbeast
  • 31 posts
  • Registered Products:3
Posted 24 August 2014 - 07:50 PM
The Red Comp (Compression) tool on the Spider IV what does it do exactly ?
And what is the "pre" & "post" option ? Is that too do with the signal ?
#2 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2574 posts
  • LocationNew England
Posted 25 August 2014 - 04:32 AM
"Pre" means it is in the signal chain prior to the preamp, "Post", means it is in the chain after the preamp.
Compression takes a lower volume signal and boosts it, or takes a higher volume signal and reduces it in volume so the overall volume is more even.  If you have compression on (and turned way up) and are not playing, you will most likely notice a hissing/noise sound building up in volume as the compression tries to bring up the volume (when there is no signal), so its boosting the background noise.  As soon as you strike a note on your guitar, you will hear the hissing stop.
#3 bcbeast
bcbeast
  • 31 posts
Posted 25 August 2014 - 03:21 PM
So what is the difference "sound wise " to my ear pre sounds more refined or more processed than post.
Which compression do you prefer ? I did the software update from 1.02 to 2.0 and noticed a lot more compression options.
Is there anywhere to get a listing of what pre-sets & effects become effective after the software upgrade?
Sorry for all the questions just trying to get all the bugs ironed out .
#4 bcbeast
bcbeast
  • 31 posts
Posted 25 August 2014 - 03:23 PM
I found a list for the software update :
http://line6.com/sup...-update-20-r218
#5 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2574 posts
Posted 26 August 2014 - 04:10 AM
I've always put the compressor post, after all other effects.
#6 bcbeast
bcbeast
  • 31 posts
Posted 26 August 2014 - 02:59 PM
So you then run the other effects pre ?
Thanks for the reply much appreciated.
#7 bcbeast
bcbeast
  • 31 posts
Posted 26 August 2014 - 03:00 PM
What compressor effect do you run ? Red comp , Vedetta Comp , Blue Comp etc ?
#8 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2574 posts
Posted 27 August 2014 - 04:14 AM
Typiclaly, I rely on the default settings for effects.  Experiment to find out the differences in sound when you switch between the various models and pre/post.  What one person likes for sound can vary too much for what someone else likes.
#9 Jimmikatt
Jimmikatt
  • 87 posts
Posted 07 September 2014 - 10:17 AM
I like to run Red Comp when i'm playing my Strat,  for the crisp country pop you get on the strings, Clapton also used this in a lot of stuff.
Also when used on a distorted channel, it will make the sustain ring out much longer.
