Just Bought A Used Ux2 Unit
ux2 ux-2 ux 2
3 replies to this topic
#1 Ford32Ford
Ford32Ford
  • 2 posts
  • Registered Products:1
Posted 11 June 2013 - 05:29 PM
I just bought a used UX2 unit from Guitar Center.  Just the unit and the USB cable.  Now I'm hearing different stories on how I should just return it due to no CD software or I can download the proper software from the Line 6 site.  So I will be using n-Track for the recording software and I have TH2 for the modeling (if I choose).  What would I need to download (if anything) to just be able to plug the UX2 into my pc so I can run an acoustic guitar into the recording software?  Any help is greatly appreciated.
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15467 posts
  • LocationOntario, Canada
  • Registered Products:15
Posted 11 June 2013 - 05:31 PM
You should download and install Line 6 Monkey first (see Downloads tab at the top of this page). Then run Line 6 Monkey with your UX2 connected via usb. The Monkey will guide you through the UX2 software installation process.
.... John Lennon
#3 Ford32Ford
Ford32Ford
  • 2 posts
Posted 11 June 2013 - 05:56 PM
Thanks for the quick reply.  So after downloading/installing Line 6 Monkey, connecting the UX unit to my laptop, run Monkey it should be able to set it up essentially?  I can then run it through n-Track from that point it sounds like.  Thanks again.
#4 BigChas52
BigChas52
    Guru
  • Line 6 Expert
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 11 June 2013 - 08:22 PM
You'll need to, at a minimum, install the latest drivers.  Monkey will help you do that.  POD Farm will be helpful as well.
Use the ASIO drivers to record in n-Track.  If you need more info, there is an excellent help file in POD Farm.
You can find all the software you need here http://line6.com/software
Also tagged with one or more of these keywords: ux2, ux-2, ux 2
